  • 4 weeks later...
  • Replies 80
FS: Full URAS Kit in Maroon but can be repainted.
PICS: http://www.nissansilvia.com/forums/index.p...&CODE=12&CID=20
NB. As we know these are extremely hard to find! I have had it on the car for several months (without the front bar), selling cuz I need the dorras. Would prefer VIC buyer :D
$350 for F/S/R
hey buddy this still for sale?
condition?
condition?
Indeed it is. Although its probably not worth coming from Sydney for. Condition is as follows:
  • I painted it myself and the clear coat bubbled. Meaning it has tiny white dots all over it.
  • Rear bar is ruff from clear coat.
  • Rear bar came off on the freeway so it has a small crack in the corner on one side and is worn right through on the underneath left (not visible)
  • Also its a 'quality' Viva Garage kit so it isnt the best fit. I have sanded skirts and is only really noticable on the right hand side of the rear bar under the light (sticks out about 5-10mm)
This is why it is so cheap. If you are going to re-paint it then the condition probably isnt a big issue. Freight would be about $100 to sydney I think as thats how much it was from adelaide. I would lurrrrve you to pick it up. Could even meet at winton/albury or something if ur really keen.
Let me know.
Edited by konect
All off my Ceffy. Open to reasonable offers unless noted. All items are in Melbourne but happy to send small items and if large items please arrange courier from your end and pick up from me. thanks
- RB20DET auto = SOLD
- RB20DET diff = SOLD
- RB20DET starter motor (EC)(3 months warranty) = SOLD
- RB20DET Turbo (No shaft play at all)(EC) = SOLD
- Stock Cat = SOLD
- A31 front guards (perfect condition) = SOLD
- A31 front bar (EC) = SOLD
- A31 rear bar (EC) = SOLD
- A31 front grill = SOLD
- A31 centre console (EC)
- A31 cluster with 96000k's on clock. (EC)
- A31 foot brake pedal setup
- S13 Tanabe Coilovers. Height and front camber adjustable. No Leaks (GC) = SOLD
Edited by gHeTTo_GiRL
  • 5 weeks later...
  • 3 weeks later...
hey guys
full A31 hubs/rotors/calipers/pads/clips for sale - good upgrade for ca owners - $200
S14 rear conversion 5 stud kit - hubs/rotors/calipers/pads/pins/clips/brake dust covers/stub axles/handbrake cables - full bolton for s13/180 - slight mod to handbrake for a31/c33 - $300
A31 navy blue bonnet - no dents - comes with shocks attached - perfect nick - $200
RB20DET hicas power steering pump - $70
A31 hicas steering rack - $100 with tie rods/ends
A31 hicas pump - $70 with connections/lines
3" A31/R32/S13 diff back exhaust - with cannon - cannon has been scraped on bottom and needs to be welded - $100
more to come as i think of it!
--------------------------------- Located in SA - no shipping interstate
WTB - S14 steering rack with rods/ends
hey guys
  • 4 weeks later...
The following items are WANTED by me in order to tidy up my car ready to sell:
-A31 hicas steering rack with tie rods/ends
-A31 hicas pump with connections/lines
-Cefiro rear windscreen wiper
-a31/s13 Front drivers side hub assembly with wheel bearing
-Swap a31 driver side seat with someone's spare to get trim to match. Currently I have the black/white patern material but the rest of the cabin is dark grey.
-Factory decent condition s13/a31 front shocks. No springs required but will buy them as well if neccessary.
I also have some spares that I can trade or let go at mates rates:
-A31 rb20det engine suit wrecking. Highlights from this include factory turbo in good nick, two full sets of coil packs (one set older style rb20 loom plug, other set new). Still have most of the engine bit and pieces, no loom but things like CAS and piping.
Please PM here to enquire.
Cheers,
Michael
safety21 c33/a31 full 6 point bolt in cage... blue padding and cage is gloss black
$650 quick sale
very streetable cage as it follows all roof and pillar lines... can only see front 2 bars going down the windscreen out the front... rest of the cage not visible on the outside!
SA
bride ergo seat fs $450
16x9-1 work merc style polished dishies... 5x114.3... 205/50/r16 stretched 50% tread... $700
Kei Office
coilovers excellent near new condition
adjustable 2 way height, damper and camber tops
8 front, 6 rear
i had these brought over by thuy and they were only in my car for about 1000 kms before i took them out.
the cars gone now so im selling up.
im in melb.
$1250ono
email
[email protected]
Edited by KICKIN
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
