Please see the attached photo's and let me know if you want anything.
Motor, g/box and brakes SOLD
17x7.5" & 17x8.5" Volk TE37's, front tyres bald on inside, rears are near new 255 toyo's.... Make an offer
All other parts available....
Will send interstate if paid for by direct deposit.
[email protected]
0411 878 961
Doc.
  • Replies 105
Interested in drivers side door inside panel thingo - the door skin, inside handle etc.
Also rear bar - is it in good nick ?? Or does it need re-painting ??
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
