use a small screwdriver to remove the 2 hose clamps, and remove. No real trick to it, you may find it easier to remove the filter from the braket to get to bottom hoseclamp
rememebr to wait for engine to cool down so you dont burn yourself on intake manifold
i just went to parts store and asked for one to fit my car.
though i might add, the stock one has a bend in one of the pipe's going into filter. the replacement they gave me, the line was straight. It worked fine, but i couldnt get the filter back in the braket
ps. check your other thread
If you go to autobarn or where ever you should be able to look the part number for a fuel filter up in the book.
The one without the bend in the pipe is for 300zx i think.
lol my names rhett 2... never met another 1..
Hey, your the 4th Rhett ive met. It took me until i was 18 to meet another person called Rhett.
What's the best way to do it without spilling fuel everywhere? As obviously when the filter is taken off the bottom clamp, and fuel in the lines is going to go everywhere? :)
I've got a spare fuel filter and have been meaning to swap it over for a while but have never gotten around to it.
What's the best way to do it without spilling fuel everywhere?  As obviously when the filter is taken off the bottom clamp, and fuel in the lines is going to go everywhere?  :P
Yank the fuel pump fuse and let the car die. Try and turn it over a couple of times and you will use up most of the remaing petrol. Have a rag to catch the rest.
I used Z 201 cost 11$ .It has straight top/out piping so You have to replaced fuel hose for longer one ,half meter 7.5 mm cost about 9 $.
Or You can use a Z 387 cost about 38$ same bended top pipe as genuine one.
Its not a problem to change I did two R 32 today .Take me few minutes .Pul out filter with smal hose from botom pipe ,than change filter out of tha car and put back filter with smal hose and top big hose already back on to botom pipe.
Fuel here is real shit so You need to replaced fuel filter at least every 10000 kms.
If You can not for same reason change fuel filter and have something to do in Brisbane ,come to my place I can changed for You.No problem.
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
