kero, a rag, an old credit card, and patience. soak the sticky stuff well with your solvent, then use the credit card to carefully scrape it off. dont go too hard or you'll end up with scratches.
Edited by jezzerrr
Yeah thats the best way. I used a bit of turps on a rag and carefully just let it soak in and it sorta turns it to jelly which is easy scratched off by finger and then just rubbed like hell to get the rest off.
Its a very slow process though.
Im still trying to get all off!
HAH finally!! Was thinking of asking this problem myself!!
Its a right bastard to get off eh?!?! It pisses me off as I lean on the car and it trys to rip the bloody hairs off my arms!!
I will get around to doing it this weekend
Cheers guys!!
The best product to use is probably "SHELLITE", should be able to find it in most supermarkets near the metho. Metho has a brown label, Shellite has the blue label.
I use it at work to remove sticky labels, off the label printers. Doesn't react with the plastic, etc.
using kero worked the best for me, i pulled off what i could by hand, then used a cloth to rub the kero on, then it was a matter of scratching the rest off with a credit card.
Only problem is there is a bit of a gap between the rubber and the door frame were the rain guard sat :S
lolz...
For the last 20yrs i've always driven with the windows down, even in winter I have to have it cracked atleast 2"...I was actually thinking of getting one of these for my 33 after finding out how much water flows in with the windows even slighty cracked in a light shower..especially when you pull up (bath anyone?)
Anyway to the point, before you guys removed your's did you notice if they actually work at all? being so small I wasnt sure if they'd have any effect.
Cheers Bung.
cheers...appreciated
Ok here it go's. They actually do work pretty well. What it mainly stops is the water that is on the roof filtering down into the car. Without them all the water gathers in the sill and streams into the cabin through the window. I guess if you ever take them off don't wind ur window down for about 2 mins after you take off. Then you'll be sweet
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
