Just installed a GT spec hybrid FMIC today and took it for a test drive and noticed the boost hit 15psi before i backed off the gas. I have it set for 10.
Just wondering if i have T'ed the line that goes to the wastegate actuator in the wrong spot. At the moment it is T'ed into the line that goes from the standard BOV back to the intake manifold. The hose is no greater than 1cm in diameter and only about 1ft long.
I put it here cause of what i read on another forum, starting to think its wrong.
Here is the pic from the thread where it said to t into
Edited by Damo
https://www.sau.com.au/forums/topic/89526-over-boosting-after-installing-fmic/
I installed mine last Tuesday, t'd the same line & I don't have a problem....I don't have an a/m boost guage but there has been nothing different. Boost comes on faster, but not over boosting. Did you use the hose that came with the kit to run it back??????
The same thread we posted in, one guy said not to use that line for some reason & he used a different one, said he would post a pic but didn't. But a couple of guys said that's what they've done & no problems.
I have to check with someone to make sure it is ok, but the upside is if it is wrong you should just need to replace the cut hose & connect to the right one.
yeah i used the hose in the kit to t it in. wierd that it works on yours but not mine. might take out the boost controler 2moro and c how that goes.
anyone else got another sugestion on where to tap into???
yeah it should be plumber into the cooler piping just before the throttle body, the stock piping had a little nipple that the feed went to. this is so that manifold presure is directly fed to the boost controller and then the actuator. theres another spot you can t into, where the stock guage gets its signal from. the plenum (6 pipe thing) if your standing on the drive side of the car looking at plenum on right end of plenum is a air tube line which runs to the stock guage. if you tee into this should work fine, mine is setup like this. othewrwise youll have to tee into the cooler piping and use a nipple setup, aka drill hole and messy
yeah this was my next option. only its a different size hose that is tapped off the plenum, its much smaller than the hose that goes to the wastegate. I was not sure of this would make a difference. Will give it a try, though i might have to buy more hose.
Fixed the problem, just had to readjust the boost controler. Tapping into another line with a much longer hose must throw out the calibration of it.
I agree with you ICER33 about drilling into the new piping, makes it much neater. Will have to do this. Can you give a more detailed DIY guide. like was any sealant required and how did you screw the nipple into it?
Cheers
    • perhaps i should have mentioned, I plugged the unit in before i handed over to the electronics repair shop to see what damaged had been caused and the unit worked (ac controls, rear demister etc) bar the lights behind the lcd. i would assume that the diode was only to control lighting and didnt harm anything else i got the unit back from the electronics repair shop and all is well (to a point). The lights are back on and ac controls are working. im still paranoid as i beleive the repairer just put in any zener diode he could find and admitted asking chatgpt if its compatible   i do however have another issue... sometimes when i turn the ignition on, the climate control unit now goes through a diagnostics procedure which normally occurs when you disconnect and reconnect but this may be due to the below   to top everything off, and feel free to shoot me as im just about to do it myself anyway, while i was checking the newly repaired board by plugging in the climate control unit bare without the housing, i believe i may have shorted it on the headunit surround. Climate control unit still works but now the keyless entry doesnt work along with the dome light not turning on when you open the door. to add to this tricky situation, when you start the car and remove the key ( i have a turbo timer so car remains on) the keyless entry works. the dome light also works when you switch to the on position. fuses were checked and all ok ive deduced that the short somehow has messed with the smart entry control module as that is what controls the keyless entry and dome light on door opening   you guys wouldnt happen to have any experience with that topic lmao... im only laughing as its all i can do right now my self diagnosed adhd always gets me in a situation as i have no patience and want to get everything done in shortest amount of time as possible often ignoring crucial steps such as disconnecting battery when stuffing around with electronics or even placing a simple rag over the metallic headunit surround when placing a live pcb board on top of it   FML
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
