You thought exactly as I did when I posted that same pic back a month or so on here. However as I was told ..."Sorry its not a skyline as its shot in the USA and they don't get Skylines, plus, the indicators on the side shot from the clip (on the bumper) are different....
Sorry to burst your bubble but someone popped mine to. Awesoem clip tho.
https://www.sau.com.au/forums/topic/899-matrix2-reloaded/#findComment-19295
Heheheh...... well
Matrix is shot in Sydney, but the highway scene was shot on a highway built just for the movie. The highway has since been torn down, it was in California near an abandoned naval base.
Because the V35 Skylines are global models, available world-wide, and they are/will be availabe in the USA.
The different bumper-tail lights are due to the many different variations of the V35 series.
https://www.sau.com.au/forums/topic/899-matrix2-reloaded/#findComment-19317
I think it blows up or something in the end.... cos it wasn't fast enough or something. So I think its best this way.
However if they intended the car to simply go so fast that it just loses the pursuing vehicles, the movie would probably lose out cos it would get kinda boring..... so its better this way I think. :)
https://www.sau.com.au/forums/topic/899-matrix2-reloaded/#findComment-19350
soooo... did the japs copy yet another design from another car manufacturer or is it the other way round this time... because both look very similar to one another.
down the drags a few months ago and in the pit lane a rx7 s4 and a porsche (whatever the model is thats like the s4, 9xx? ) were next to one another and its good to see the japs have their own unique way of styling things
:lol: :lol:
Shaun
https://www.sau.com.au/forums/topic/899-matrix2-reloaded/#findComment-19451
that shot is friggin crazy! the agent actually flips his own car and starts shooting through his own windscreen while he is flipping in the air just to get a few shots at the cadillac cts!!! that is insane! of course the agent doesnt give a stuff what happens after that cos he just goes back in through another human body / entry point or whateva the popular term is for that sort of stuff.
yeah... ;)
https://www.sau.com.au/forums/topic/899-matrix2-reloaded/#findComment-19885
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
