Got quite a few bits and peices lying around so im trying to get rid of them
This includes :
**UPDATED**
*1x Drivers Apillar - 2 small drill holes - GC $15 each
*1x Passenger A Pillar - VGC $20
*1x Centre Console with box storage compartment - crack inside box otherwise fine from outside $50
*Interior lamp assembly GC - $30
*Cigarette Lighter VGC $15
*Complete glove box VG $40
*Standard Rear Springs - VG $50
*interior door handle surround VGC $20
*Rear passenger complete door trim and Roof lining part VGC $50
*Passenger Door Trim, bottom part where store Cd's cracked, otherwise fine, can be repaired easy $50
*2x Sunroof motors VGC $ 80 each
*Rear aftermarket wing GTR style, painted white, GC $50
*Standard Intercooler GC $50
* 2 x 17inch impul wheels, tyres are Falcon Azenis(wide 255) and other Jap brand (235), good for track $100 for both
*Rear left Upper control arm VGC $30
*M-Spec Front Foglights in immaculate condition $150 for the pair
For all the dummies :
GC = Good Condition
VGC = Very Good Condition
pics hopefully uploaded this weekand if i get a chance...
Andrew...
Ph 0412 675 321
Pickup Castle Hill or Burwood
Edited by onBOOST247
https://www.sau.com.au/forums/topic/89936-r33-bits-n-pieces/
I'm after the left rear passenger hand grip (bolted on the interior roof lining) if you have it.
I can come pick up at Burwood.
Your talking about the grip handle that u use to hold on to? Im pretty sure i got that, i'll have a look 2nite ... if i do $20 and its urs.
Yeah that's it. It's for the left rear seat passenger to hang onto when I take a fast left hand corner... :lol:
Let me know tomorrow if you have it and I'll swing by on the weekend to Burwood to pick it up.
Cheers...
Interested in the following:
Are they still available? Can pick up as I live in Sydney.
have alot of interest , but both are still available, im in Castle hill sydney
i'll be there 2nite, you can come pick them up if u want.
  • 3 weeks later...
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
    • Fuark, at least the motor survived. What brand was the fitting that snapped?
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
    • Measure voltage at the starter solenoid terminal when the key is at start and it has clicked. If it is really low, then the suspicion falls on the ignition switch (contacts or wiring thereof) as causing a voltage drop instead of sending enough volts to throw the solenoid all the way to engage the starter itself. If it is a decent voltage, then the suspicion is on the solenoid. Might have s horted coil, or might hva dirty contacts. Rip the starter off, dismantle, clean up contacts and inspect winding. It might not be possible to see if there is a short in the winding though. I have a spare starter here that I could measure the resistance of the coil, as a guide to about what it should be, if you need a comparison. <parts hoarder>No you cannot have it.</parts hoarder>
