Hiya all...im wondering what would be the advantages of having the hand controller and not having one with the Power FC. Say the tuner who will do the tuning of the car does not need the hand controller, so what benefits would there be to the owner having one?
https://www.sau.com.au/forums/topic/89965-pfc-hand-controller/
debug any problem
adjust the tune yourself
adjust rev / idle settings
try temp ign and fuel correction yourself
change airflow meters yourself
check factory oem sensors for problems
monitor overall tune in real time
monitor max values for each item to look for unsafe levels
without the hand controller you may as well have a remapped ecu imho
i have the hand controller and use it pretty much as often as i drive my car, to watch for knock, check airflow and injectory duty. watch for sensor check to try and debug my cold start issue. to temp adjust ign timing for some more fuel economy
Wot values is the hand controller capable of displaying and how do we actually see if the engine is knocking or not on the hand controller?
Basically then the hand controller can show how many % the injectors are running at? Cuz im not a ecu guru and am wondering how hard is it to actually know wot im tuning or changing with the hand controller.
Is it right to say that fer the occasional track-goer, the hand controller is a definite must?
hand controller is quite usefull. it displays:
knock
water temp
revs
speed
inlet air temp (in GTR)
afm voltage
injector duty
voltage
probably more stuff that i've forgotten. i use it quite a bit just for monitoring and sometimes adjusting rev limit.
Hmmm i guess the main values that i will want to observe will be the knock and injector duty.....
Anyone can tell me if there is 1 or 2 power fc fer the r33 gts-t? As in the series 1 and 2 r33, do they run different power fc? Or its just 1 standard power fc made fer the r33 gts-t?
And i'm pretty confused with my car cuz its a march '95 car, it probably is the s1.5, but does the 1.5 have all the same engine n internals n turbo as the series2? I think theres no ABS on my car although i'm not sure, i don't have the passenger airbag and well my front bar is not a series2 front bar.
hmmm ok...have u had any experience with this mismatch? Cuz alot of people and workshops hav told me that the hand controller is universal fer all power fcs.
Better not listen to those people again, and avoid those workshops because they are WRONG. I have seen 6 different models of Commander and I haven't found one that will work on any Power FC's other than the model/models it is listed for. ie; there is no universal one. For Nissans, there are 2 Commanders that seem to do most models. From memory the 415-X001 is by far the most common. And the 415-N001 is for use with the later models of Power FC's. Check out the application chart for your particular model.
:D cheers :O
knock - shown by a flashing engine warning light when you have a PFC
water temp - Shown on the instrument cluster on all skylines (called a temp guage)
revs - Shown on the instrument cluster on all skylines (called a tacho)
speed - Shown on the instrument cluster on all skylines (called a speedo)
inlet air temp (in GTR) - so you know the outside air temp. I use the weather service on the news to get this (the day before)
afm voltage (never needed to know this)
There are other devices you can use to monitor/log your engine figures, and a log over time is probably better than trying to read it whilst driving.
I dont have the controller, I trust the tuner (which I am not and never will be) to set the car up correctly on the dyno. I worry about those who tamper with their PFC hand controllers and end up with a car out of tune.
Everyone one has their own opinion, but I wouldnt consider having one as a necessity
you are not a very sharp cookie mate. the air conditiong display shows ambient or outside air temp. the inlet air sensor is mounted in the plenum chamber, so it tells you the heat of the air that your engine is ingesting. hahaha, you are a pretty funny guy you call the weather service to get an reading of the air temp inside your inlet tract? you must have a very special service.
as for the factory water temp gauge, you must be kidding. it sits in the middle from about 50 degrees to 95 degrees... it's very close to useless.
speed, after a run it's usefull to be able to recall your peak speed. and i can tell you that @ indicated 180kph the speedo is a fair way out, and past that there are no marking? so what are you reading? your hand?
i won't bother explaining the uses for any more of the displays to you.
HEHEHE, funny beer baron :D
J-Boy, hand controller is extremely useful. On saturday, the warning light falshed on the dash for a sec or two, with out the hand controller, I wouldnt have known that the power FC had just recorded 98 knock..?
First time ever, usually sits about 10-20 under full load and this was at night time.. Very useful tool..
Yeah i think after all the comments and advice, i'll prob get the power fc with the hand controller...think the knock display and injectory cycle would be of the most concern to me on the display of the commander to me...
Beer Baron - i have a Blitz RVIT which displays all of those firgures besides Knock, its a good little unit, its basically the Power FC hand controller it can be used on the std ECU, basically same thing as the Niss Dat scan tool.
Gives, injector cycle, ingition timing, air flow, revs, speed, water temp, intake temp.
Got it for $320 from Autobarn brand new
yeah RVIT is handy, but if you had a power FC you would be mad not to use the hand controller as it does lots of things the RVIT etc can't do. and it costs about the same price.
nissan consult tool is like $80 :)
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
