  • 3 weeks later...
  • Replies 244
Posted Images
one a side note a member who purchased a datalogit on the 11th of novembner 2005 recieved his datalogit invite to the user groups today so they are still activing and looks like the datalogit guys may be playing catch up. so there is light at the end of the tunnel
in summary
adjust rb25 variable cam timing rev setting (when it turns off)
save / reload tune data
advanced log all sensors and MONITOR items
advanced log external inputs (wideband 02)
supports antilag, boost scramble
mine has already paid for itself by allowing me to save / reload my tune a few times, log all sensors and support wideband tuning
besides letting you graph the knock levels, and being able to save your config, is there anything else the datalogit lets you do that is useful ?
Page 2 :unsure: of this thread i wrote:
Ok, for tuning purposes the hand controller does basically the same as the datalogit. BUT there are a hell of a lot more fetures which imho make it worth the little extra...do a search and you may be suprised what you can do with it :D from SK:
OK, but only the ones that you can't access via the Commander
Inlet air temp fuel map
Water temp fuel map
RPM acceleration fuel map
Cranking Injector dwell map
Water temp versus boost fuel correction
Inlet air temp versus boost fuel correction
RPM Load Point table
AFM load point table
AFM voltage table
Ignition versus water temp correction
Ignition versus inlet air temp correction
Ignition dwell versus RPM correction
Ignition versus battery voltage correction
Ignition versus boost correction
Individual injector trim
Injector lag versus battery voltage correction
Via the Datalogit there is also;
Antilag via injection
Antilag via ignition
Intercooler spray
Basically anything that you want to turn on or off
Then there is the logging
Every standard sensor is logged
Plus 4 others (eg; lambda, brake temperature, suspension travel etc etc)
as well as :
All of which are important once you reach the limitations of the stock afm/load point base map setup.
Swapping to a Z32 or VH41/Q45 AFM does zilch in its own.
Software is required.
There's also the A/C and non a/c overheat fan temp switch.
heaps. As well as for datalogging, i can hook up an afr meter and do logging on the street with AFR values, so i can do my own light throttle tuning to get better fuel economy.
I only have to pay $100 for a WOT tune, then take it home and fine tune myself (which is about another $200 on the dyno)
my contact reports that the latest version is 1.120 for RB25 which I now have (pm me if you want it) and unfortunately the latest version of the manual (if any) are not in the user groups so we can't get access to the latest manual.
Also to note there are lots of posts about anitlag not working for lots of people and little to no help or comments from the datalogit team on how to make it work either
My invite to join the user group arrived this morning. Very happy.
    • Hey mate, really appreciate the help. Have been looking pretty extensively myself and was certain they were retro fitted, but then ended up finding a 4 door with what looks like the same side skirts or at least the closest I’ve seen. The photos from the Offset Kings event at Sunrise 2016. https://fatlace.com/offset-kings-okayama-at-sunrise/
    • Isn't there a PAR engineering gearset that has closer to stock ratios? And they claim they'll do whatever ratios you want.
    • And this is the the thing with a high powered, AWD, heavy car. The engine is easy, the driveline costs just as much as the engine. 🤷‍♂️ Welcome to GTRland. Whatever you think your budget is, double it. Whatever you think your timeline is, triple it.
    • I thought I'd heard rumor of someone that was developing a 6 speed kit to convert the 5 speed box. But maybe I was thinking of the PPG 6 speed sequential? That's about half the price of a car...
    • I've searched fairly extensively among Japanese websites but found nothing really like those skirts in your photo. The closest I got was Origin Labo side skirts however they look more 'complete' in that they have a finishing piece or tab at the rear of the skirt so it blends into the bodywork, unlike the one in your pic. For that reason I'd say the skirts in your pic could be adapted from another car and they didn't include that tab piece, or those skirts aren't copied from an existing skirt but an original design. Sorry I can't help out in regard to ID'ing/sourcing them
