  • Replies 58
i put a just jap bellmouth front pipe on recently and it bolted up perfect. lined up to standard cat position without any modding. this was on an RS4s
D.
how much heat comes through to under your passenger seat now if you removed a heatsheild? as i have amps underthere and JJ haven't gotten back to me about wether any standard sheilds fit(or top half if its clamshell) :blink:
  • 8 months later...
i finally bit the bullet and got a custom mandrel bent 3inch on my s2 auto... it's flippin awesome but 1st - 2nd it hits the rev limiter twice and the gear change completes at about 100... has anyone had similar problems or is it time to work on the box?
the turbo is running in high boost mode with the shorted solenoid
  • 1 year later...
Theres not much talk about mufflers being used and how they go with drown. I have a RS4S with a standed dump,cat with a 3inch SS to 1 muffler from hi-tech mufflers (not a canon) and it sounds great but i just cant settle with the drowning. Im thinking of putting a hotdog in there and see what difference it makes.
+ if your warried about the heat shield on a different dump why dont you heat wrap it???
Edited by BR11GY
Im using a justjap 3" bellmouth dump/front pipe into a 3" gutted metal cat, bolted onto 3" catback into 3" magnaflow resonator (hotdog) into 3" straight through kakimoto 'gtr racing' muffler
only drone noticeable is at around 1800rpm
free flowing enough for 250kw@wheels - rs4 auto
  • 1 month later...
Some cool info on here!
I've got a S1 Dayz eddition that came with the optional Nismo exhaust, just curious if anyone knows what the pipe diameter of the Nismo units are, I could probably take it off and measure it up but that requires some effort :nyaanyaa:
Just thinking whether it's worth replacing if it's 2.5 inch or something, or just making up some blast pipes for track/drift days.
Anyone know if it's a full system, catback, or axle back only?
Edit: Shit sorry, I thought this was an exhaust thread ... maybe we should make a sticky with something like "What exhaust are you running".
Edited by RoadsterGarage
My S2 came with the Nismo exhaust, from what I was told it's a 2 1/2 inch cat back. I assume the one on the S1 is the same. I thought about just replacing the cat and dump/front pipes to make it 2 1/2 inch all the way, but after doing some reading and asking around ended up making it 3 inch all the way through and love it!
ohk cool! Thanks for that.
So what made you make the switch, what are you running now and did you notice any power improvements from the Nismo item? (I suppose you would considering you swapped the dump pipe and such).
I had initially planned on getting the front of the system through to the cat in 3 inch, and then having in joing out of the cat back down to the existing 2 1/2 inch exhaust, but after doing a bit of reading on here and talking to my tuner, I decided to go 3 inch all the way. What I was told was that it would be too restrictive having it 2 1/2 inch and I was better off having 3 inch all the way to get the best performance. I am running a HKS Hi Power cat back, but I am not sure exactly what brand hi-flow cat or dump pipe, but I'm assuming they are X-Force or something along those lines. Something decent quality without being a major brand. As far as power improvements, I did a Nistune chip, fuel pump and boost controller at the same time, so it's a bit hard to tell exactly how much difference the exhaust itself made, but with that combination and no other mods apart from a HKS pod filter, I am getting 204kw at the wheels on 10psi.
Hope that helps
How loud is that Tim? I might even make something up myself where I can use the Nismo rear muffler for street, and blast pipes for the track.
It is a lot quieter than I expected. I actually noticed very little difference in car, and even outside the car it is not that loud. I think I hear my pod filter more than my exhaust lol
Just remember a oval muffler is always going to be much more quiet than a cannon. they're notorious for noise. not to mention drone.
my setup on my gtr. std dumps, jjr down pipes. xforce cat, custom catback with xforce oval muffler with titanium tip. very quiet on idle. zero to no drone.
Edited by Mingy
  • 2 years later...
bumping old topic but didn't want to start another one,
looking for an cat back exhaust fro my stag, can anyone confirm skyline exhausts fit and if its just a case of changing the hangers or if its shorter?
$T2eC16FHJHQFFhnGq1ycBRyPLy,(Mg~~60_57.J
this seems to be the same shape, its off a r32 gtr.
cheers
  • 4 months later...
I just had a cat back exhaust off a 4 door r32 fitted to my s2 stagea. Needed a few cuts to rotate it slightly, a section added before the rear axle to lengthen it and the hangars moved. It was Mild 3" and had no center muffler, just a varex on the end, so it was easy to modify, only cost be $100 to get fitted. Sounds great too :)
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
