RB20det 5speed gearbox for sale. 79000kms on it
came out of my front cut and not required!
unsure of working condition but it feels ok!
$400 ono
FMIC kit for r32 GTS-T, 260x260 small cast iron HKS stage 1 kit
for the r32's... may even fit r33GTS-T's aswell.
have all pipes and joiners!
$150
im located near castle hill..
reply/pm for more details.
or cal me on 0401 664 828
cheers!
https://www.sau.com.au/forums/topic/90221-rb20det-5speed-gearbox-for-sale/
bump stuff still for sale. i will try and post up some pictures later this arvo or tonight of the intercooler!!
gearbox is negotiable, FMIC stage 1 kit.... $150
lots of interest but no money coming my way, so its still for sale!
cheers
~GIFFO~
sorry to all that have pm'd me, camera isnt working yet!!
will try again tonight?!?!?
if not bare with me on the cooler!!
stuff is still for sale!!
$150 firm on the cooler
$320 on the gearbox?!?
any takers
Edited by Giffo
mate, unsure what u mean about the cossmember!~
it came off my r32GTS-T and has everything to bolt up to your original plumbing. IF YOU NEED HELP installing it, i will fit it for you!
will to ship/post if buyer can organise and/pay for the freight.
cheers!!
hey mate
is castle hill sydney,do you have any other parts?
pedals?im looking at a skyline tmrw and i wannaknow what im looking at for a box etc as its auto:(
i think guy before meant crossmember regarding box as in gearbox crossmember.
so box hasnt been checked at all?
mate i have felt the box and it feels ok, its dry at the moment and has no oil in it!
yeah i have a spare gearbox crossmember aswell
sorry no pedal box assembly mate! a friend took all that away!!
i do have a wing, stock blow off valve and FMIC for sale though!
yeah castle hill area, thats where im from and yes its in sydney!!
cheers!!
offers?
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
