Item:17" Genuine Volk Racing rims
Specifications:- 5 stud
- 17x8 front
- 17x9 rear
- light weight
- Rear Deep dished
-Front deep dished
- comes with all nuts and bolts
-comes with used spacers
- great condition
- Was previously on a supra
-should suit Nissan Skylines, and other toyotaz with 5 stud patter and possibly holdens with a 5 stud pattern
Item Condition:Perfect
Price and Payment Conditions:$1000
Extra Info: Will post anywhere in australia at buyers cost
Contact Details:0414468844
Edited by sarah77
https://www.sau.com.au/forums/topic/90226-for-sale17-genuine-volk-racing-rims/
what offset and stud pattern??
-should suit Nissan Skylines, Mitsubishi's, Holden Commodores and other Toyota's with 5 Stud pattern.
holden commodores have different stud pattern to nissan skylines!? are the wheels multi stud?
please find out what offset they are.
skyline offsets are around +30ish
supra offsets are around +50-60ish
which means, wheels could sit too far in the guards and possibly hit brake caliper / suspension. It's important to get offset right for wheels to fit properly.
supra (jza80) rims are 5x114.3 which are same stud pattern as skyilne / ford / s14 / s15 / rx7. but offset's differ. supra wheels are usually similar to FC, but higher offset to skyline.
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
