after a set of coil packs and the coil pack module (that little black thing sitting at the back of the engine)
if you can sell them let me know,
contact 0410412941
thanks mate
i want to sell the thing complete. sorry.
https://www.sau.com.au/forums/topic/90241-rb20det/#findComment-1665281
Come on make an offer, i will consider anything.
will trade for:
New computer
Some spray painting work - bonnet and wheels in charcoal
programmable computer (i will top this trade up with cash aswell)
MP3 player - at least 20 gig memory
or something else just ask
https://www.sau.com.au/forums/topic/90241-rb20det/#findComment-1665292
  • 4 weeks later...
mate, is it just the head gasket or other stuff as well? Looking for a engine for my silvia, but its a pig so dont wanna have to spend much on it,
Matt
sorry for the late reply, i have been away.
without pulling the engine down i don't know exactly whats wrong with it.
from my mechanics inspection it seems to just be the head gasket. the engine runs, and the more you run it the better it gets but you can see the water and oil leaking from the gasket.
i would really doubt that there is any head or cylinder damage. i was'nt pushing it when it overheated it simply ran out of coolent due to a hole in my radiator.
price is $300
https://www.sau.com.au/forums/topic/90241-rb20det/#findComment-1788526
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
