Guys i need a new clutch as mine is f**ked.
I have an RB20E, its out of a 33 GTS.
I can only get an excede (spelling) heavy duty clutch for the r32 gtst (rb20det) but i would think the engines would be the same...
Can someone verify if i can get the excede heavy duty clutch for the rb20det and use it on the rb20e... help is needed urgently. clutch is totally gone:(
Dayne
https://www.sau.com.au/forums/topic/90380-rb20-clutchs/
as far as I know, all the rb20 blocks are the same
E, DE and DET is all in the head (OK, technically the pistons too, though I would presume the crankshaft is the same)
but, yes, the clutch shuold bolt right on...
Are you sure that you can't find another less heavy clutch? Not that there is anything wrong with it, but it would probably feel pretty heavy compared to your old clutch.
anyway, good luck with it.
-ebola
https://www.sau.com.au/forums/topic/90380-rb20-clutchs/#findComment-1631622
