  • Replies 109
Posted Images
i wonder with that amount of bling under the bonnet if they would arest you 4 having a WEAPON OF MASS DESTRUCTION F*^% mate did you win lotto 1 off the best engine bays i have ever seen beautiful very beautiful
man....you need a ticker Raditor and better brakes.....you done anything on the handling.....as everyone can noticed the R33 alway have under steel in the concer
The radiator in there now is thinker and as he said brakes are on the way....
no he is a fat german/polish man small hands type ... everyone give him a call. oh yea you can see his car on his web site were most of my parts are for sale ... he should be selling a complete engine,pioneer indash dvd , full custom fuel system , t51rspl, 80mm external wastegate,front and back strutt brace, greedy plenium, hks intercooler, hks air pod,1000w kenwood amp , motec m8 pro computer, greddy fuel managment system these are a few of the parts stolen so give him a call ...
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
