Hey guys its about time to replace my front tyres now i love the look of really wide tryes, ATM i have 255/35/18 on the rear, can i put 265/35/18 or even275/35/18 on the rear will they be too wide or will the 255's on the front be too wide for the fronts? and more importantly will it negatively affect the handling?
Also on the front at the moment the profile is 40 will it matter if i swap my rears the profile will be 35? thanks any imput would be appreciated.
Thanks
https://www.sau.com.au/forums/topic/90785-tyres-how-wide/
what size rim do you have? get hold of a tyre sizing chart or speak to a tyre shop, ask them what the limit is for width on that size rim.
there is a rule of thumb that suggests you should put the narrowest recommended tyre possible onto a rim if you want it to handle as it stiffens the sidewalls.
but you've said you want the look so if you can put up with going slower, feeling more bumps, tramlining and the extra cost go right ahead.
just j/k - it's up to you but there is a down side to wide tyres.
as for the profile, as long as the rolling diameter (use the tyre size chart to find out) is the same it makes no difference. i think there is a legal tolerance with rolling diameter - about 15mm from stock from memory.
as for fitting your car it depends on the offset of the wheel, ride height etc do a search and you'll prob find a discussion on what fits an R33.
Edited by GTR32
https://www.sau.com.au/forums/topic/90785-tyres-how-wide/#findComment-1635179
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
