I was talking to a Mech yesterday on getting my car dyno tuned and he said you cant do it properly if you place the probe into the end of the exhaust, as when the cat warms up and is at operating temp it shows an incorrect ratio. He said the only way to do this is to drill a hole and weld a nut in the pipe in front of the CAT and place the probe there. Has any one done this? Also does the probe have a screw in adaptor if so what size nut would be needed?
Cheers
What a load of crap! I have never heard of this before and EVERY tune shop i have ever been too puts the probe in the exaust pipe at the rear of the car.
If you put the probe in the dump pipe in the standard oxy sensor position it can get very very hot and then you start to get weird readings....
You can get a fitting that you weld into your exhaust from just about any exhaust shop. sure the reading may be a little more accurate in high HP applications but anything within 250rkw i wouldnt worry about it...
Ive been told about this too by a few experienced dyno operators. They prefer to punch a hole before the cat and read the measures from there. I think it would give a more accurate result but still i cant complain about mine being measured from the rear.
it does make quite a difference. from my personal experience with this it seems the readings taken post cat are on average richer than those taken without a cat. i couldn't say if it's always like this, but that was my observation with my own car.
At high load and rich mixtures the cat wont be able to make any impact on the readings. So provided you allow for the slight lag of the gas reaching the rear of the exhaust for measurement it will be fine when tuning.
At light load lean mictures and around stoich mixtures, the readings at the rear of the exhaust or after cat will not be entirely correct. But then again these mixtures aren't real critical anyway.
Sometimes tuners just prefer the quicker response of the lamda sensors placed in the turbo dump or pre-cat positions so its easier to tune.
It will only cost a few bucks to get a 18x1.5 bung put into the downpipe, so just get it done if thats what the tuner prefers.
I have a wideband that actual has a simulated narrow band output as well, so i basically remove the factory sensor, screw in the wideband, and just use the narrowband output to connect to the ecu and the wideband output to the laptop for accurate readout.
Makes so very easy.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
    • Yes it is ATF. I quote @Duncan "it takes a good synthentic auto trans fluid like Castrol Transmax Z" It's not a diff. It's a transfer case. Totally different thing. Yes, fluid will come out the sender hole. No you do not really need to drain it. Just pull the old, quickly poke the new, clean up and top up. But realistically, you should probably take the opportunity to change it anyway.
