Can u guys help me out on this one because ive got no idea. Ive got a sky and need some help on the fluids that are recommended for it.
I know that engine oil should be changed every 5000kms with good full synthetic oil as well as have the oil filter changed.
What about
- transmission oil
- radiator coolant
- power steering fluid
- brake fluid
Can u use any type of fluid or do u have to use special ones that are specifically designed for high performance cars???
Some recommendations on the fluids u guys are using for your Lines would be appreciated
thanks
https://www.sau.com.au/forums/topic/9101-engine-fluids/
I use Silkolene DOT4 for my brakes. Its damn good compared to the crappy Mobil and Castrol that regular auto shops stock.
Good sources for quality fluids, both transmission and brake, is motorbike shops. They stock really good brands like Motul, Belray and Silkolene. One type of racing brake fluid Silkolene make retails for about $38 for 500ml's! I use the cheaper $16 dollar one which is good enough for most people id say.
Generally i change brake fluid once a year, but I dont do alot of motorsport, so it tends to get changed when I can feel the pedal is horrible. :D
I use Mobil 1 10W/30 in my Skyline for engine oil.
Red17
https://www.sau.com.au/forums/topic/9101-engine-fluids/#findComment-136994
So engine oil doesnt really matter which ones u use just as long as they are full synthetic rite?
thanks for the brake fluid tips i think ill hope down to my local bike shop and pick up a bottle of that stuff.
With transmission oil and brake fluid do u have to flush it or can u just top it up???
Sorry to be a hassle but one more thing guys...do you have to flush the radiator coolant or can u just top it up with Nissan's radiator coolant when it gets low
Thanks again
https://www.sau.com.au/forums/topic/9101-engine-fluids/#findComment-137497
You can just top it up I'd say...but every now and then (maybe once a year) do a full flush, because often stuff can just sit at the bottom of the radiator. Once i thought my radiator was clean (and the water was), and heaps and heaps of crap came out of it.
https://www.sau.com.au/forums/topic/9101-engine-fluids/#findComment-137553
Skyline_Paul: I just changed the oil in my gearbox and they feel as smooth as silk. I used Caltex Gearlube 70w-90 coz thats what they recommend for the car and its well worth it (used about 3.5 litres)... no more nasty clunking. For the engine I used 5w-40 Full synth (nearly used 5 litres). For the gearbox all you need is a 1/2 inch rachet (the square bit opens the bung) and the motor you need a 14mm ring spanner or rachet depending on what you perfer.
Filter for motor No. 145a
Petrol Filter Z200
Cheers
Sumo
https://www.sau.com.au/forums/topic/9101-engine-fluids/#findComment-147598
Hey Sumo thanks for the help i havent yet changed anything on my car yet...since i just got it the other week
just wondering how long should u leave it until u have another gearbox oil change? (kms??)
and also are u from the west cause i need some help...i am crap when it comes to car engine maintenance
cheers
https://www.sau.com.au/forums/topic/9101-engine-fluids/#findComment-150214
Im in Country NSW. Near Tamworth.
If you had all the filters and oils would only take half a day to do max.
Changing the oil in my Diff today, EP 85w-90 was recommended for the R32 GTR, but it reads its not recommended for LSD's? Im not sure whether the R33 is a LSD or not?.
Sumo
https://www.sau.com.au/forums/topic/9101-engine-fluids/#findComment-152089
Oil Filter = Z145a
Fuel Filter = Z201
Air Filter = A360
If you have and Auto you are best to change the Trans Fluid and filter every 50,000k's. If you have and LSD, which all Turbo Skylines have you should change its fluid with the trans flud. An lsd is almost useless if the Fluid is maintained. Manual Trans Fluid should really be changed at 50,000 to 60,000k's also just to b safe, especially if you drive it hard. Coolant Should be changed every 2 to 3 years and Brake Fluid every 2 years. Power steering fluid really should last you 100,000k's.
Im fairly sure the pads on all skylines are:
Front = DB1170
Rear = DB1220
Discs; (Not 100% sure if these are right for r32 GTST)
Front = DBA4963
Rear = DBA908
I use NGK BCPR6EVX Plugs in my R33, but if you drive hard you should use a 7 heat range. BCPR7EVX
https://www.sau.com.au/forums/topic/9101-engine-fluids/#findComment-169010
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
