ok guys
some background first... i got epa'd....
i have a s1 r33 gtst, before i went to the epa i re-installed the std turbo+ecu+injectors+air flow metre ect ect and started her up. all working fine. took it for a test drive no more then 500 metre and she just died on me(no smoke no sounds). i tried to start her again and nothing... tried again and she started fine so i drove home,
kept the car running for about 30 min with no strange signs.
next day i drove to epa (about 45min) and passed.... no more then 5 min after i left it happened again but this time she wouldnt start (tow truck home)
ok so...
-the engine cranks
-all fuses are fine
-dont get fuel pressure (fuel pump fine)
-windows dont work
-none of the dash warning light up
-turbo timer does no light up
-alarm works
-radio+lights work
any ideas would be great
https://www.sau.com.au/forums/topic/91152-elecrical-issues/
Sounds like a power supply problem.
Check the connections at the battery, check the earth point in the boot, give it a clean with a file if you want to be sure.
Then have a look at the earth points on the engine block. Check out the power supply cable on the starter and the connection going to the fuse panel. Then you can start doing voltage drop tests, from the battery to the starter etc. It can even come down to a crook end crimped onto you main power lead.
Cheers
Sumo
https://www.sau.com.au/forums/topic/91152-elecrical-issues/#findComment-1642754
ok so...
-the engine cranks
-all fuses are fine
-windows dont work
-alarm works
-radio+lights work
red -- you sure about this one ... if you dont get fuel pressure then the pump is not getting power .. this is controlled via the ECU ..
do the lights on the dash go on when you turn the key??? like the engine light and oil light etc come on when cranking..
mine shuts of for 1 second when turniong mine over after putting the power FC in. then come on and it starts!
the turbo timer shouldn't come on til your key turns to acc.
https://www.sau.com.au/forums/topic/91152-elecrical-issues/#findComment-1642760
hey sumo
ill be checking all the conections tomorow. (but the head lights and radio work)
why wouldnt the windows work?????? or the turbo timer????
that stuff isnt connected to the ecu is it...???
i have a feeling it could be the ecu or a short somewhere along the power lead (as you stated) or both...
https://www.sau.com.au/forums/topic/91152-elecrical-issues/#findComment-1643516
craved
i have a fuel press gauge so yes im sure and u can normally hear the pump when key is on acc.... but this is not happening at the moment.
the lights on the dash do not come on (key on acc) or while cranking
and turbo time doesnt come on when key is in acc possition either...
is there any way of checking if power is going into and out of the ecu???
ill be putting my pfc back in later on this week,
https://www.sau.com.au/forums/topic/91152-elecrical-issues/#findComment-1643537
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
