Hey. I dont know if this is the right place to put this, but i dont think i can put it in the for sale section.
anyway, my mate has a car and we're trying to figure out what its worth. he imported it himself and wants to know what he could sell it for.
ok. its a 1995 Toyota Supra RZ. Twin turbo 6 speed.
its bog stock. absolutely nothing done to it. has stnadard 17inch wheels, (i thought they came with 16s). the interior is immaculate, the outside has some minor panel scuffs and a small dent (that will be fixed before he sells it).
its got 66850 on the clock atm.
ive looked around, and there is a huge gap between dealers and private sales, but the private ones all have heaps of k's.
if anyone can give me a ballpark figure of what its worth, or even what it could sell for, then can you let me know?
and i dont mean what you youself would pay for it, becaiuse i know all skyline owners know a bit more than the average car owner. specailly ricers.
well, thanks for your time
https://www.sau.com.au/forums/topic/91219-toyota-supra-rz/
Not as much as skylines, skylines chew more petrol than supras =) and skylines are heavier than supra by not alot but maybe around 40-100kg at least thats wat i saw
last tiem i checked no... supra's weigh 1600+ kg
and supras use much more fuel, bigger CC, heavier.... etc
https://www.sau.com.au/forums/topic/91219-toyota-supra-rz/#findComment-1650034
I've got a mate trying to sell a 93 RZ auto with light mods for about $21k, so i would think a nice stock, no hassles 6 spd 95 model would fetch a nice price. just check things like gearbox and clutch because stock sometimes means it's been driven by drivers who don't know what sort of car they've got
https://www.sau.com.au/forums/topic/91219-toyota-supra-rz/#findComment-1651129
hahaha!
nice supras aiight car and all.
3.0ltr Twin Turbo.... and they weight is 1490kg (manual twin turbo) and the R33 (manual Gtst) weight is 1370kg....
i was comparing it to the RZ with the sky gtst series. I think ur puttin it againtss the GTRs.
Yeh bud, dam.... the head room in the bk is shocking....
I still cant get ova it. Mates got a Sz-R and took me home from a party one night along with other mates. I was put in da bk and dammmmmm 15min driving was sooo bad :P
and im not that tall of a guy.
Hahahaha
https://www.sau.com.au/forums/topic/91219-toyota-supra-rz/#findComment-1652158
hey hey hey. i did post it in supra forum. i just wanted a non-biased opinion.
but thanks all for the imput. and they do suck when it comes to room and fuel. i dont own it, i have a chaser. i big, roomy, economic supra, which weighs less.
thanks all, now i just gotta convince him to sell it while its worth anything. he dindt know what its worth cos it only cost him 23k to import himself.
i was in the back once, with 2 other ppl, so 5 all together in a 4 seater. im not tall, but my head hurt, and i cramped up. very un-useable, especially since he's a plumber.
https://www.sau.com.au/forums/topic/91219-toyota-supra-rz/#findComment-1654910
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
    • Assuming your brake pads are not worn right down, I'd add a little brake fluid. Is there any sign of a brake fluid leak?
    • Hello all,  I need of some help. On my drive home my handbrake light lit up and started flashing. When I got home I checked my handbrake sensor under the centre console and nothing seemed out of the ordinary. I have scanned my car via the consult port, no codes shown. Checked my brake fluid as well which is half full. Tried unplugging the brake master but it didn't change anything. Thoughts on what it could be? The master float doesn't seem to be stuck. My car is an 1998 ER34 sedan GT. No hicas but has ABS Photos below 👇🏾
