you cant just place a manual conversion on them can you? or is there too much work involved....
not so much work...cost is the thing 25det manual box`s are expensive ..not easy to find,34 manual front cuts = next to nil,so some new parts have to be used + engine management +steering wheel+console ..easier said than done...the big difference between 34`s and 32/33 silvia etc is that not so many manuals have been sold new so conversions will be a lot harder
I'm kinda new to the whole R34 scene...So the 4 doors do come in manuals though dont they? :rolleyes:
4dr 5 speed available ..just dearer eg:
1999 SKYLINE 4D GT TURBO Manual 5 Speed 67,000km silver 4.5 1,523,000YEN.....
1999 SKYLINE 4D GT TURBO Auto Transmisson 69,000km pearl white 4.5 913,000YEN....
that works out at $8800 difference in the 2 cars
R34 is where Nissan finally got the sedans looking as good as coupes. I would recommend the R34 Tiptronic Sedan. Great as a daily driver in traffic, but able to change gears at will in the hills and twistys. You'll be able to get a grade 4 series 1 in for low-mid 20's.
I recently bought a 1998 R34 4 door GT. Non turbo version. Im here in kiwi land and you guys in Aussie pay a shit load more for your imports than we do here, compliance costs must be pretty harsh. Mine has 87,000 kms on the clock is in mint condition and I paid NZ$14,000 for it, I think thats somewhere around Aus$12,000.
I bought the 4 door over he 2 door because of a couple of reasons. Firstly work requirements, i work as an advertising photographer and i have to lug around a bunch of lights and camera gear all the time so the 2 door isnt really practical. Secondly cost, the 2 door is outside my budget right now, maybe in 2 years time i will look to buy a 2 door but it will have to be a second car because of the work thing. I'm not a huge fan of station wagons.
Absolutely love the car although i do think its arse end looks weird, i think its because the wheels have too much of a gap between them and the wheel arch, it makes the wheels look small and strange. Not sure what the best option is so any thoughts would be appreciated. Im considering lowering the car a small amount to close that gap, just a subtle drop. I quite like the idea of keeping the car relatively straight looking. Also there is the option of going for bigger rims with lower profile tyres but i have been told that mucks up your speedo?. Not sure if thats true though.
If I had the budget and work hadnt been an issue I would have gone for a 2 door turbo version.
As long as your rolling diameter remains the same it won't affect your speedo much or at all. Tire shops will be able to recommend you the correct profile tires to go with ur wheels. The arse end can be improved heaps if u chuck on some 18x9 deep dishies with 40 or 35 profile tires. :P
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
