Hi Guyz,
Currently getting some mods done on my R32 GTS-t and I am a bit concerned about what type of power I should expect at the wheels (in KW). The mods are as follows:
* HKS Type S Intercooler
* 650cc SARD injectors
* Garrett 30/37R Ball Bearing
* Tomei Poncam Cams
* Apexi Power FC (Re- Tuned)
* AVC-R Electronic Boost Controller
* Top Mount Manifold
* HKS Air Pod
* Z32 Air Flow Meter
* 38mm External Wastegate
I am hoping to get at least 240+ KW at the wheels. Is this a big ask??? Have any of you guys ever seen a RB20DET with these type of mods, if so what type of power did it get at the wheels???
Looking forward to hearing back from you guys ;)).
Regards
Bruno
https://www.sau.com.au/forums/topic/92013-rb20det-mods/
Welcome to SAU . It will make that power easy, probably only need 16psi to do it.
A few good RB20 threads around. Main thinh is with a std motor thats probably got a few kms on it, and is over 13 years old is the tuning and maintenance (oil & fluid)
It will be reliably make that power, but make sure the tune is spot on.
https://www.sau.com.au/forums/topic/92013-rb20det-mods/#findComment-1659261
Hey Roy,
Thanks for the post. It amkes me feel better to hear your confidence with the mods I am having done aiming for 240+ at the wheels. One thing I didn't mention is that I also have a intank Walbro 500hp hi pressure feul pump and an adjustable fuel reg.
At the end of this stage of mods if I have 240+ at the wheels and am in the 12's I will be very happy.
Regards
Bruno
https://www.sau.com.au/forums/topic/92013-rb20det-mods/#findComment-1659504
Well im running a slightly smaller plain bearing turbo making 230rwkws. And the thing is pretty good fun, and it has snuck into the 12s with a mph that indicates that a low 12 is achievable if i suck down a can of tuffen up and launch the thing properly:)
Thats one thing to remember, run good gearbox fluid. PPl rate redline shockproof, i run and rate Castrol. The gearboxes dont have a great reputation, but mine is still going strong with 180,000 under its belt and plenty of use at tracks so just take it easy on the shifts and it shouls last
https://www.sau.com.au/forums/topic/92013-rb20det-mods/#findComment-1659985
  • 4 weeks later...
Hey Guyz,
As promised I am coming back to you with the dyno results on the upgrade to my RB20DET. I had originally tuned my car on a dyno dynamics dyno and got 176kwrws (before I got these mods done). At the time I only had the HKS type S intercooler, the Apexi AVC-R electronic boost controller and the HKS air filter and was running 1 bar boost.
This time round the car was tune on a Mainline Dyno which I was told it actually reports less power at the wheel because of the bigger rollers that the tyres have to spin. I have the boost controller set on 2 different settings, the everyday setting running 1 bar of boost and the drag setting running 1.3 bar of boost. The boost seems to be kicking in at 4000rpm (with the help of the Tomei cams), I may consider getting cam gears to try reduce the lag as doing this isn't a costly exercise.
Results:
Every day boost setting 1 bar
On the everyday setting running 1 bar I was able to get 194kwrws with 498MN of tourque.
Drag setting 1.3 bar (peaking at 1.4 bar)
On this setting I was able to get 237 kwrws with 625nm of tourque.
I am also going to run the car on the original dyno I had tuned it on (the Dyno Dynamics Dyno) to see if there is much difference between the 2 dynos.
I am also yet to run the car down the qtr to see what time she pulls and am hoping to try get into the 12's with this setup.
I am also selling the following parts due to the upgrade:
* R32 GTS-t injectors full set
* Stock RB20DET Manifold
* Pair of RB20DET Cams
* HKS Air Pod (use replace because the HKS would fit my engine bay because of the mods)
* Unused Adjustable fuel reg (brand new)
I have also attached some picture of the upgrade for those of you who are interested.
Once again guys thankyou for all you advice and if anyone has any question about the mods done plz dont hesitate to contact me.
Regards
Bruno
FST32R
https://www.sau.com.au/forums/topic/92013-rb20det-mods/#findComment-1729767
Hey Guyz,
Results:
Regards
Bruno
FST32R
Your tuner is crap!
I am getting 210rwkw on standard injectors, standard AFM and standard remapped ECU.
With the mods you have listed at the top your power output should be EASILY over 280rwkw.
https://www.sau.com.au/forums/topic/92013-rb20det-mods/#findComment-1729807
Hey Guys,
Thanx for the comments. 3lit3 where was it you got you car tuned and secondly what type of dyno was it? Was it a Dyno Dynamics? I respect you comments but this are very important factors and finally we could have gotten alot more power out of that turbo but had to be carful as the car is still running stock internals. I will say one thing though, Bel Garage done a great job not only on my car but allot of are performance cars out their and please keep in mind different dyno's will always give different reads as i mention on the post above. But hey if you are a sydney sider like myself maybe we should just have a run down the creek and see how good our tuners really are :mellow: .
Nathan_G1 yeah it is laggy my friend thats why I may investigate the option of changing my cam gears.
Matt hows doing bud. I got the turbo fairly cheap as it was a part of the overall package (I think I paid $1900-$2000 for it). The turbo was supplied to me from Bel Garage.
Regards
Bruno
FST32r
https://www.sau.com.au/forums/topic/92013-rb20det-mods/#findComment-1730361
What type of dyno was your car tuned on and who tuned it?
with 210rwkw your injectors would be maxing out, also what turbo you running stock aswell?? you done cams or anything?
Line 'em up and let the driving do the talking :mellow:
Bruno great work on your car, results look fair, you gotta take me for a spin one day. :blink: woot woot.
Your tuner is crap!
https://www.sau.com.au/forums/topic/92013-rb20det-mods/#findComment-1730450
Hey Jago,
Nah the engine was stock. The only mods I had back then was the Apexi Power FC, the boost controller and the HKS intercooler. Please also keep in mind that this was a reading on a dyno Dynamics Dyno that do had the reputation of spitting out higher figures as they have smaller rollers that are easier for the tires to spin.
ITZFUN, thanx for the reply bud and yeah I guess those are my questions as well to 3lit3. And bud as I said to Morgs same goes to you bud. We should get together for a cruise or something.
Thanx once again lads
Regards
Bruno
FST32R
https://www.sau.com.au/forums/topic/92013-rb20det-mods/#findComment-1730474
If i can offer one bit of advice it would be to ditch the stock afm and get a z32. Unless you've changed it since you took the engine bay picture.
I'm partially colour blind but that looks like a green sticker which is rb20/25, orange is z32. Also the plug looks like the gray 20/25 plug.
Cam gears shouldn't be needed with poncams as they are optomised to be a drop in cam.
If you are getting full boost by 4k then i would be happy with the peak power figure. It would be worthwhile getting a run on a dyno dynamics dyno though so you have a figure comparable with everyone elses.
https://www.sau.com.au/forums/topic/92013-rb20det-mods/#findComment-1730482
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
