My GF just got a new honda jazz and we had it fitted with a sunroof. The dealer told us that this wasn't a stardard option from honda. He told us that the sunroof that was going to be put in was going to be done by the company who puts it on BMW (forgot the name of the company). I have to say it was done very nicely. Full electronic control. Makes me want to get one for my R33 but i would rather do the performance first.
It cost us an extra $2500 for the sunroof.
I think the ones that dealers get for cars that don't come with them factory-optioned are done by Hollandia. I'm pretty sure their standards are high, so you shouldn't have too many issues. As mentioned, it will probably be big dollars though.
I'm pretty sure that's who does the new car ones, but don't quote me on it.
Do a search through the Yellow/White pages (or Google it) and you might get a list of workshops contracted to do them.
sweet................ a sunroof is kool since its summer now its worth the moeny also not many skylines have sunroof i've seen a few with them so does any kkow now the address or that place its pretty pointless checking in the yellow pages or google it. just scared they are not reilable and the moeny will be wasted
its cool when ur mates smoke in the car they can blow it out the sunroof, see if they have the windows down they are gonna get ash all over my car i rather them ash it in my ash tray and blow it through the sunroof....... but then yeah it sounds alot for just a hole i nthe roof
Dude, I'm pretty sure Hollandia will be reliable - IIRC they have enough of a reputation to be doing kits for new car dealerships both with sunroof installs and also power window kits.
I found this link to help you with a search, just in case you do wish to go ahead and/or find out more on pricing...
Also found this link too, for a direct link to Webasto.
You let your mates smoke in your car??? :D
If one of my mates did that, I'd hit the eject button and send them straight to the sidewalk...
Anyway, back on topic, a friend of mine had a Webasto sunroof on his Astra SRi and never had any problems with it. I know it cost him a packet to get fitted though and I think the novelty of having it wore off after a while.
Personally, I think sunroofs are a nice thing to inherit when you buy a car (i had one on my Prelude and loved it), but I could never justify paying the $2.5k to get one fitted.
Wouldn't you rather spend the money on go fast bits or a nice set of wheels???
point 1, no one should smoke in your car, unless you are talking a big fat blunt which is acceptable. even you should not smoke cigarettes in your own car.
point 2, if it was me and i really wanted a sunroof i would get a GTST with a factory nissan sunroof. much better. plus they brace the roof differently in sunroof models to counteract some of the lost strength.
yeah right ~~so u are saying u dont smoke in ur car? :rolleyes:
actually no, there's not much bracing around the R32 factory sunroof... different shape roof support bar, that's about it.
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
