hey, got a quick question..
well im thinking of selling my gtst r33 s1.5 1995 .. and i wana know how much it would go for roughly atm. i got it about 3 months ago since then, put new tyers on it, new clutch, and just did the rego like last friday. just ticked over 100,000kms. pod, boost controler, BBS gold rims. new front bar (not sure what type it is, but i think its some version of a gtr style). car runs smooth. all in good working order. gona get the front disk breaks machined later this week and get new break pads for the front..
what kinda price ya think it would go for? im thinking more around $18,000, $18,500 and is any1 here interested or know of some1 who is? .. plates start with AQT-*** .. there not personilizd, so ya dont have to pay extra on rego each year.
oh, last time i got it dynoed, it was 195rwkw
edit: forgot to say also, new sound system inside, pioneer head deck, $300 220watt competition component speakers in the front (website link), 160watt pioneer 2 ways in the back. GReddy Full Auto turbo Timer. 3 point imobilzer alarm, 3" exhaust from the dump pipe, momo steering wheel, um lol.. so much more, just isnt coming to mind atm.
Edited by ranicx
I think $18-$20k is reasonable for a neat, mildly modded Series II.
You'll probably have to be patient while waiting for a buyer though. A lot of buyers will want to drag you down on price because there are cheaper Series I examples on the market these days. There's also a lot of crap on the market, so if you're car is in good nick, then most buyers will see the value in paying a little more.
Already selling? Getting a GTR? :P
yea around 17-18 would be good.
yeh selling already, and yup, importing a gtr r33 :D
thanx guys.. and yeh its in very good nick, never had a crash in its life, only imported last year, very good inside and out. hence y i got it, lol.. the nrma guy that did the inspection was realy impressed the condition it was in
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
