hey guys, not a big deal but something i still would like to fix. just installed a new dvd player and moniter, when its all switched off you can hear the alternator whine through the headunit i think, but when switched on even with no volume it goes away. just wondering if you guys have any ideas, thanks.
https://www.sau.com.au/forums/topic/92293-funny-one/
i know if you have the alternator whine coming through your amp you run the rca lead and the power lead down different sides of the car... but dont know how u could apply this to your problem... a little food for thought
https://www.sau.com.au/forums/topic/92293-funny-one/#findComment-1683647
thanks for your response, it does seem like some sort of interfearence problem. havent rechecked anything yet but will do soon after it goes back on the dyno. it isnt a daily driver and i only play with it when i have nothing to do so im not in a big rush. thanks.
Russell.
https://www.sau.com.au/forums/topic/92293-funny-one/#findComment-1684579
get a new balist resistor for the back of you alternator its a little cylinder attached to it. Next bad earth somewhere (dirty) most likley your remote lead from head unit to amp. Next power cables to clost to speaker or rca leads. They pick up signals from power cables and play in the speakers
https://www.sau.com.au/forums/topic/92293-funny-one/#findComment-1694407
if you havent had any problem's with whining in this car before and theres no-interferance anywhere from an outside source, its most likly a grounding problem as mentioned ealier, it could also be a power leak somewhere into either the ground loop or the 12+ loop, if re-grounding everything up mabye try running just one long wire from the gound of the dvd unit straight to the earth in the battery just temporaraly if the whine goes away its a problem with your ground loop, so try gorunding in a different spot or use a different route, if it still occurs it could be a 12+ problem which is more difficult to fix, if possible try a different power source, if all fail's find somone who has an ossiliscope thingy which meausers your power/ earth frequency's and try and source where the interfeerance is comming from, other than that mabye it is an alternator causeed problem, which i doubt if the sound does go away, another possibility is you may have your remote wire plugged (or any of the dvd wires) into the wrong spot and so it could cause some sort of feedback when the unit is off but then when it is turned this wire could react different with constant current running down it, i know i had this problem one time when i grouned a mates head unit up to what seemed to be an earth wire n turned out to be an accessory wire which stayed earth untill activated, if all fails try temporarly installing the dvd unit to an external sources (another car, or threw a computer -- or some sort of 12 power sorce) and make sure the gear isnt the problem
https://www.sau.com.au/forums/topic/92293-funny-one/#findComment-1698808
    • I see, honestly I’m not too fussed about the looks. The only reason to go plenum is to make the piping easier instead of the classic over the rad etc.
    • Not easy to quantify wrt something like how many fractions of a second slower it would be over 0-100. But given that a 250-300rwkW car is able to do that launch sprint in 5-6 sec (and faster with appropriate tyres, and surface)..... giving up as much as a second would feel like torture. A ~450HP capable turbo is not going to make lots of boost in the 2000-3000 rpm range. So, whilst with some boost on hand it will be faster accelerating in that rev range than your engine currently is NA, it will not feel like a fast car until the boost is solidly in. You know what your car feels like right now when you open it up at 2000rpm. if you've ever been in an actual fast car, you will appreciate that the NARB25 is.... not exciting. Well, add some boost and it will be better. But shorten the intake runners and it might not be better at all. It might come out better, but it could end up feeling the same. For me, it's not the 0-X km/h sprints that matter. It is easy to fry the tyres with anything over 200 rwkW. You can't use all the power available in 1st and 2nd anyway, you have to modulate the throttle. What matters is how the car reacts when you're driving in traffic in 4th or 5th and have maybe 2000 rpm on board, and you want/need to add some speed quickly, and don't have time for the downshift. It won't make boost, it will be all NA (at the speeds we're talking about - remember how fast you're going at 2000 in 4th! and don't plan on breaking the limit by too much.) So giving away NA torque is not what I would consider practical for a street car. And retaining that NA torque builds boost faster which makes the car faster. The flashy plenum is not actually better, unless you're looking at a track car where you can keep it on the boil all the time.
    • So how much difference does it make you think? Like 1 second in the 0-100?  I was have smaller turbo so hopefully that spools quick GTX2871.  currently it’s NA so you can imagine pretty slow, but I do want fast accusation a little as there’s not many places I’ll be driving where I go over 80 even near me. So 0-60 and 0-80 targets
    • Short inlet runners cost quite a bit. Dulls off the off-boost torque, and delays boost onset, because arrival of boost is driven by gas flow is a product of the ability to flow air which is torque. This is the reason that the stock manifolds have longer runners. On a 3L, or bigger, you can usually accept the compromise of giving away some torque because the extra capacity gives you a little extra to waste. But on a smaller motor, there's not a lot there to start with. Example, I swapped RB20 out of my R32, 25NeoDET in its place. The "wall of torque" that I experienced afterwards made it all worthwhile. That's because I came from RB20 land where torque is not a thing. But I would not do anything, anything at all, to reduce the low/mid torque I have now, because I remember what it is like to not have it!
    • Really, low/midrange torque goes really bad?? I want decent acceleration, maybe I use a stock rb25det neo manifold?
