hey guys, not a big deal but something i still would like to fix. just installed a new dvd player and moniter, when its all switched off you can hear the alternator whine through the headunit i think, but when switched on even with no volume it goes away. just wondering if you guys have any ideas, thanks.
https://www.sau.com.au/forums/topic/92293-funny-one/
i know if you have the alternator whine coming through your amp you run the rca lead and the power lead down different sides of the car... but dont know how u could apply this to your problem... a little food for thought
https://www.sau.com.au/forums/topic/92293-funny-one/#findComment-1683647
thanks for your response, it does seem like some sort of interfearence problem. havent rechecked anything yet but will do soon after it goes back on the dyno. it isnt a daily driver and i only play with it when i have nothing to do so im not in a big rush. thanks.
Russell.
https://www.sau.com.au/forums/topic/92293-funny-one/#findComment-1684579
get a new balist resistor for the back of you alternator its a little cylinder attached to it. Next bad earth somewhere (dirty) most likley your remote lead from head unit to amp. Next power cables to clost to speaker or rca leads. They pick up signals from power cables and play in the speakers
https://www.sau.com.au/forums/topic/92293-funny-one/#findComment-1694407
if you havent had any problem's with whining in this car before and theres no-interferance anywhere from an outside source, its most likly a grounding problem as mentioned ealier, it could also be a power leak somewhere into either the ground loop or the 12+ loop, if re-grounding everything up mabye try running just one long wire from the gound of the dvd unit straight to the earth in the battery just temporaraly if the whine goes away its a problem with your ground loop, so try gorunding in a different spot or use a different route, if it still occurs it could be a 12+ problem which is more difficult to fix, if possible try a different power source, if all fail's find somone who has an ossiliscope thingy which meausers your power/ earth frequency's and try and source where the interfeerance is comming from, other than that mabye it is an alternator causeed problem, which i doubt if the sound does go away, another possibility is you may have your remote wire plugged (or any of the dvd wires) into the wrong spot and so it could cause some sort of feedback when the unit is off but then when it is turned this wire could react different with constant current running down it, i know i had this problem one time when i grouned a mates head unit up to what seemed to be an earth wire n turned out to be an accessory wire which stayed earth untill activated, if all fails try temporarly installing the dvd unit to an external sources (another car, or threw a computer -- or some sort of 12 power sorce) and make sure the gear isnt the problem
https://www.sau.com.au/forums/topic/92293-funny-one/#findComment-1698808
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
