$400 FIRM WITH RAIL
Item: GENUINE Bride ergo with R32/R33/A31 genuine bride real
Item Condition:Good slightly faded but other than that good has a tiny hole in the ass of the seat which i can fix
Reason for Selling: Got 2 bride brix seats in the 34 :(
Price and Payment Conditions: $400 with rail , will send interstate at buyers expense
Extra Info: Dog ISNT included :lol: for pics leave your email address here and i will send them out. I am negotiable but to an extent.
Contact Details:pm or email [email protected]
Edited by ABTO
https://www.sau.com.au/forums/topic/92678-bride-ergo-with-rail/
you've got 2 brix seats? does that mean you rip off your backseat?
interested with your seats but I cannot open the link to your picture
how much would it cost to deliver?
any damage on the material or frame?
thanks
huh? ohh no that's not what I meant...I'm curious since brix are non reclining I wonder if is it possible to fit a non reclining seat and still can have ppl sitting at the back...but you removed your seats, ripping backseats is a term I used with my mates referring to removal of the backseat…sry abt that dun mean to be rude..
thanks anyways...
yes you can use the bride seat without havint to take out the back seats, the seat origionally come out of my friends R32, i was going to use it in my R34 but i no one would swap rails and it was time consuming and i just got my tax return.
As long as you dont use a harness im about 90% sure you can still use the seat.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
