As it says guys if we want to be dickheads lets do it here.
http://www.wsid.com.au/MajorEvent.asp?Even...age=Information
Please post intrest as Leech thinks hes going to whip my arss (more then likely will)
No slicks Lee. I still dont have a camber kit either.
This has been brought up due to ppl winging about friday nights events. SO lets get a group and go race.
https://www.sau.com.au/forums/topic/92684-wsid/
lol i never said i would win i actually said i would loose but i want to see by how much :( just out of interest whats the go in terms of how early you have to be their for a checkin type thing eg could i drive up after work eg 4pm or something have a couple of runs then drive home ???
https://www.sau.com.au/forums/topic/92684-wsid/#findComment-1671979
i'm not going to bother, my car isn't a sports car and i don't drive it like one :D would be good to watch though, but wsid is a bit far on a friday night.
i think its only on wednesdays anyway and as if not take the stag up awd + rb25det would be great not sure how heavy those beasts are though
well maybe we look to get a bunch of us up early jan ???
https://www.sau.com.au/forums/topic/92684-wsid/#findComment-1672512
i'm not going to bother, my car isn't a sports car and i don't drive it like one :) would be good to watch though, but wsid is a bit far on a friday night.
Sports car?
You don't need a sports car for WSID... any car can go flat stick down a straight line :D
https://www.sau.com.au/forums/topic/92684-wsid/#findComment-1672648
it's not the awd and rb25det, it's the auto + 1800kg with fuel/driver that makes it slow. i'm going to keep this wagon in good condition, then when i get the Autech, i'll take it on a track (RB26DETT + 5spd awd wagon)
https://www.sau.com.au/forums/topic/92684-wsid/#findComment-1672793
SOFTTTTTTTTTTTTTTTTTTTTTTTT it seemed to keep up fine on friday
https://www.sau.com.au/forums/topic/92684-wsid/#findComment-1672938
Autech? MMMmmmm...260RS=yummo! When's this changeover gonna happen,Termi'?
https://www.sau.com.au/forums/topic/92684-wsid/#findComment-1675403
this sounds awesome.......
however, i do think if it is to be organised, it should be done for some time in the new year. its a wednesday night, some ppl need to get the time off work and this gives us plenty of time to organise one.......
https://www.sau.com.au/forums/topic/92684-wsid/#findComment-1676261
ok so the general consences is to have this after the new year, ok sounds good to me i was hopping sooner but hey there is already plenty of things coming up soon, like formals and Cars in the park on THE 20th OF NOVEMBER
Edited by race_snooze
https://www.sau.com.au/forums/topic/92684-wsid/#findComment-1676689
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
    • I definitely know the first rule here, look first, ask second. I've seen many people get roasted 😂 I found a few diagrams for the RB, but I'm yet to come across one for the VQ. From what I have read, the pump gets the +12v along with the FPCM, and it's the negative wire that gets passed through the resistor to regulate the voltage. So I assume I can just ground the negative wire at the pump to eliminate the FPCM control. But I really wanted to see the VQ circuit diagram first to make sure I understood it correctly. Once the new pump is in I'll do some testing to see how it behaves, and in the meantime, I'll keep looking for a wiring diagram. Thanks for your help mate, your time is greatly appreciated.
    • Maybe? I have the Supercheap ToolPro low thingo. It has a somewhat smaller diameter lifting "bowl" than you would expect on a workshop grade trolley jack, and a split rubber pad to suit that diameter. It clears the "N1" style skirts I have. Probably wouldn't if the jack's bowl and a suitably larger rubber block were in use. Having said that though.....you only need the rubber block to exist on the inner side of the pinchweld, so could carve away any rubber that fouled the skirt, leaving some there for "insurance" </simples>
    • I used to do that (sills with rubber jack block).. ... then I got side skirts, and there's no way for the jack to actually work there, the jack pad itself on the jack is too big. Is the answer to use a... smaller (?) jack? Hmmm.
    • I have too much trauma from every skyline I've ever seen having crushed jack points/pinch welds lol.    Yep, works 100%, it's what I use when I'm using the quick jack. Don't know why I can't also bring myself to do the same thing when I'm using a jack. I blame the skyline PTSD.
