Item:Mild Steel Dump & Engine Pipe for RB20 & RB25
3 inch - Mild steel - 1 piece
Item Condition:Good, few straches no dints cracks or leaks, used for less then 5000kms
Reason for Selling:Now have highmount, with S/S pipes
Price and Payment Conditions: SOLD
Extra Info:Suit R32 GTS-T, R33 GTS-T & R34 GTT, Sensor in pics not included.
Contact Details: PM or Reply
Edited by XZLA.8
This would be the equivalent of BATMBL's 3" front/dump pipe yeah? Any indication of performance gain?
I will buy it off you if it is 100% compatible with 34GTT and does deliver similar performance gains to the BATMBL front/dump pipe :)
Please reply here or PM
Not to sure to tell you the truth, I know it will bolt up to a R34 RB25, and has to be better the the factory one.
Rs,
I will buy it off you if it is 100% compatible with 34GTT and does deliver similar performance gains to the BATMBL front/dump pipe :D
I read that they fit on fine but its got a slightly different angle kick at the cat side of the pipe and the mounts are a bit off. I cant find it again it must have been on page 50 of some massive post :rolleyes:
Im sure it will fit with a bit of modification but for the extra 130 bucks for BATMBL's one its much of a muchness :-) Unless your good with a welder...
I read that they fit on fine but its got a slightly different angle kick at the cat side of the pipe and the mounts are a bit off. I cant find it again it must have been on page 50 of some massive post  :D
Pics have been updated,
This lined up perfect with my turbo and cat, it may very car to car depending on the size, lengh and shape of your cat tho.
Rs,
    • Mine is all -12, I’m running a dry sump in a billet block though
    • HG's high flow is not "bolt on". The core is shorter, moves the comp cover rearwards in the engine bay. means you have to deal with the inlet plumbing a little bit. This is probably something to consider with every "bolt on" turbo anyway.
    • HyperGear. Just get a high flow of the stocker. Good, reliable, and should bolt on. Yes it will want things like a retune once done, so you need to factor this in to your spend too.
    • Hi. Iam looking for some "cheaper" bolt on turbo on RB25DET NEO. I do not want "big" power just better reliability than the stock turbo which is "fot now" good but is old and i do not think it has "easy" life. One the Skyline here running some "temu" china Turbo but i dont trust those... Thanks!
    • Hi guys, Making some space/cleaning up. A whole heap of random OEM R33 GTR parts and other random bits and bobs. I will update this thread as I go. Parts are located in Moorebank NSW 2170. Pickup preferred but will post at buyers expense. Prices are negotiable. If they don’t sell it will go in the bin. Item 1: BOV return pipe. $40 Item 2: RB26 cam gears. $20 Item 3: R33 GTR torque split, oil temp, boost centre gauge. $100 Item 4: RB26 fuel rail x 2. $20 each Item 5: RB26 Recirc valves. $50 Item 6: OEM upper front arms. $20 Item 7: Royal Purple Max Gear 75w-140 1 quart/946 ml x 5. $50 each or 5 for $200. Item 8: OS Giken 80w-250 diff oil 1 litre. $25 Item 9 Eibach springs. ers-11-140-60-0140. $100 https://www.streetfx.com.au/eib140-60-0060-eibach-ers-140mm-length-x-60mm-id-coil-over-spring?_ga_campaignid=22235933977&_ga_adgroupid=180146800292&_ga_keyword=&_ga_device=m&_ga_target=pla-295238231169&_ga_locint=&_ga_locphy=9071723&_ga_matchtype=&_ga_network=g&_ga_device=m&_ga_placement=&_gcl_id=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE&gad_source=1&gad_campaignid=22235933977&gbraid=0AAAAADPiTbo1xAuvnjIWWYnezivf-BUSY&gclid=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE
