i think this may be a common problem with cefiro's,
i tore(spelling) mine aswell and at the time read up about a couple of others that had the same happen.
it ended up being cheaper and stronger to remove the cradle, cut the sides off and have new side mounts made and welded onto the original cradle.
picture the lower control arm. it has 2 mounts holding it to the craddle on one side, and the other side is where all the brake stuff is. the bit that snapped is the rear mount out of the two holding it on the cradle...it's not the camber arm, or caster arm, or toe arm, it's the other one (lower control arm :)) i'll get a pic of it if you really want to see which one it is :)
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
