Hi all
Every now and then I get a distinct burning rubber smell driving the car normally. It only hangs around for 5 seconds then goes away.
I am pretty certain its not the clutch as it doesnt smell like one and there doesnt seem to be a pattern. Note: this is normal driving, not harsh driving.
Any ideas?
https://www.sau.com.au/forums/topic/92892-burnt-rubber-smell-from-r34/
i fink it's from clutches man..
do u half clutch?
coz my mate used to hab rubber kinda smell after he drives when he didn't even drive hard..
but later i notice he uses half clutch a bit..
so yea..
try not to half clutch.. c if u get dat smell..
my r31 silohouette used to smell like burning rubber for a while when i put a 2 1/2" zorst on... there was a flap of rubber near the diff and used to smoke if it touched it... definately wasnt my clutch... i didnt worry too much on the assumption that if it does it enough the part thats touching will soon wear away and it did...
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
