hey adrian question for ya
my rb25 head has r33 gtr cams and r33 gtr valve springs, can i wack poncams for a gtr straight in?
if so how much improvement u reckon could be had from it...
ben...
Due to some good professional advice, I have decided to open up my RB25 & get some Tomei cams & cam gears. Can you list prices soon? (say within a month or 2?)
I wasn't going to open up the motor again, BUT now I have decided to make 3 final engine upgrades. -- Tomei Head Gasket, Tomei camshafts & gears & finally a GAS setup (gas only to be used for the drag days which I can attend due to work commitments)
Next waiting to go on is a Full Titanium Greddy/Trust Exhaust, Greddy/Trust Radiator & new body kit & panel respray.
I AM A SERIOUS BUYER, SO PLEASE LIST YOUR PRICES. I can reach 300RWKW (CURRENTLY 285rwkw) without cams, but I want to keep boost down as much as possible. My aim now is to crack 400RWKW -- Then no more mods for me, just regular servicing & enjoying my car.
Cheers
0404 323 989
i might too be interested if i can sell what i have for sale in the other items section. Dunno if i should go high lift or not. I'd have to do more research first to see what would be best for my setup
Guest
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
