  • Replies 42
ah yeah bad luck JeeTeeEss25Tee aye i saw you dyno it.
what did rigoli tell you after it?
thx alan. rigoli told me that the exhaust manifold was restrictive given the rests of the mods was pretty much free flow (FMIC, 3' zorst, filters, . . .) and the turbo could made more power coz its not an R33 item. I'll just wind down the boost for now till the problem is found.
Thanks for all who attended and by the sounds of it ppl where generally happy with the event. Some very respectable numbers from the skylines.
Everyone had a chance on the dyno and as for power figures the GTR's came 2nd & 3rd from memory. I will try to post the list sometime this week.
Thanks again
hey john... you know how the stock red 200 ran 115kw? .... the stock silver 200 ran 125kw with just an airfilter... shows how much diff a decent air filter adds power
I know those guys. They're brothers.
gtr's came 2nd and 3rd.
I know I got 203.7kw at all 4 but my car is running rich (a/f didn't go over 10.7,should be sorted by next week)
I wasn't there to see the send GTR what did it get? Was it the gunmetal grey r32?
hey im new.
it did turn out a good day.
met some new people! bbq was great. an damn man the vtir was off the hook lol.
me an my bro went in the 32 GTR and with the 34, silver DC5R, blue gti-r an corolla gti.
does anyone have any more pictures?
I've got a few more pics but I think I left before you guys came.
Edited by Scandrew
Hey Guys,
Alot of pics are on the way and the power list is been compiled as we speak. To answer some of your questions:
- Yellow corolla came first with 280rwkw
- The 2 top GTR's (gun metal r32 & white r32 with gold rims ) from memory made between 250-260rwkw. in 4wd mode one of them made around 220kw.
Good event & great figures from those who participated.
Hey Guys,
So they all got beaten by jnr godzilla?
GTiR made 221kw at 4 didnt it?
better than the GTRs?
mick
yes thats right wrxkilla, one of the GTRs made around 220kw at all 4 fours but customer wanted rwd mode to show peak power. So if table was categorised by 4wd mode then rankings would look something like this:
1st - white GTR (~225KW)
2nd - GTIR (221KW)
3rd - Black GTR (~220KW)
with the heat on that day i think everyone would get at least extra 10kw in shoot out mode  :D  but ye some impressive results there.  gw with the pics Scandrew & mac30
The Dyno used at Power Tune is a dyno dynamic and therefore does not show shoot out mode. As JeeTeeEss25Tee said ur figures would be slightly higher if it was.
yeah we ran 220.??kw on all 4wheels.
our car is a black GTR, not gunmetal grey, we just sand it down..cause we are repsraying it while im talking nows.
and yeah were pretty happy with the result, not much major mods an we pulled out that much.
if anyone has any pictures, from that girl taking pictures on the day. could you pm me or just post them up here.
il appreciate it if you do so.
    • This car has run before on this z32 ecu can get the part number for you, I have tried with no AFM it didn’t change anything, I compression tested today 140-150 across all 6 cylinders, also set fuel pressure to 43psi. The only weird thing was cylinder 1 plug was black and fouled other 5 cylinders were just wet with fuel. Spun cas by hand and confirmed injectors are clicking
    • Since you came here to ask for help, have you thought about answering our questions, that might help us lead you to why it was skipping, or have you given up on getting advice?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
