here it goes, i am offering R32 GTR owner or GTs to come foward for sponsorship
i will need the car for 1 week, what i am proposing is to deveopp your guards for a wide vented R32 Skylines Drift style.
in return, u will have a wide vented guards for just leaving your car to me :D .
for candidates, please foward pics of your ride to [email protected]
candidates have to be able to promote together with us in shows or Track/Drift/Drag as part of Topstage campaign.... car have to be clean..
Edited by topstage
https://www.sau.com.au/forums/topic/93560-r32-owners-readsponsorship/
  • Replies 41
ur not talking about a widebody kit are you? ie. Front and Rear... just a simple 20-30mm flare rather than wide guards.
Cause if your talking wide guards, wouldnt you need to modify the front and rear bars at the same time to fit like all proper widebody kits?
if u do it properly u cut the panel underneath so no... it doesnt. and the fronts people make are just replacements so theyre lighter again.
altho for the rears i spose if u do it really properly you replace the whole section rather than pop rivet so even lighter again.
Has how much does a few rivet's weigh?? gezzz  :)
DUDE! Seriously. If you have a GTR that is prepped for race or drag this does make a difference. If the widebody kits are not installed the way inark stated IT WILL make a difference.
And it’s just not a matter of pop rivets (regarding weight)? INASNT have you fitted a wide body kit before? <_<
And u have a fully prepped track GTR do ya???
Guys ive seen Freddys work and its absolutely amazing!
Now if u cut into your rear guards and chop away at it and replace it with lighter fpr ones, and replace your aluminium (GTR) front guards with lighter fpr or carbon fibre i could bet my balls on it that you will save weight!
Also how many cars in D1 try their asses off to reduce the weight then go and bolt up wider front and rear guards, so it mustnt be that much heavier if any!!
if his car is in his avatar...it does look like its kinda nasty :(
HAHAHA!
Coz the 99% of R32 GTR's on the roads are not fully track prepped and wouldnt be that concerned about a few extra kg with a new kit!
99% really? I have seen a fair few R32 GTR's come out of Racepace with 400kw+ but I see your point.
Look I'm not criticizing any workmanship and there are more than few GTR owners out there that consider weight issues (me being one of them). I think the though of having a widebody GTR is pretty cool but only if done right (as stated by inark).
Not bagging any workmanship here!
What would you define as fully race prepped?
IMO, upgraded engine/turbo+ supporting mods, brakes, suspension, weight reduction, i.e removal of most of the interior etc etc.
So, i think in terms of street driven GTRs, the weight difference would be negligble.
400kW or not (assuming those cars have more than just a drivers seat and a few tachos!)
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
