Originally posted by RONIN
mate, give it a rest
1 I'm not your mate , I don't know you and it takes a lot more than a posting to become one
2 I agree that not everyone reads every post so a double up can occur . This was pointed out by my posting ( albiet probably not very subtely )
3 He is actually a member of this forum and your
* he got owned * is insensitive to some one who has just damaged their pride and joy.
Ken
https://www.sau.com.au/forums/topic/9365-doriiiiiiift-oops/#findComment-142160
1. I apologise that I made an insensitive comment
2. I believe that "Welcome to Yesterday" was not the best way to inform MISGSR that another thread on the topic existed and am glad that you can see that
3. Mate was used in the context to address you casually. I did not imply that you are my mate or vice versa
https://www.sau.com.au/forums/topic/9365-doriiiiiiift-oops/#findComment-142174
Ken
whos a :shake: hole.:P:);):D
https://www.sau.com.au/forums/topic/9365-doriiiiiiift-oops/#findComment-142588
man u guys r uptight !!!
"IF" u must know why I finally joined here, it is not only coz I have friends on here and like to cruise with them, but I like to vary my vast knowledge of motor powered vehicles..
*goes back to "non keyboard jokey" orientated and much faster car forum (GSR_evo)*
later
https://www.sau.com.au/forums/topic/9365-doriiiiiiift-oops/#findComment-148832
    • Yes, I had ordered the spherical bushings at the same time as the rest. I have high hopes for the anti squat reduction kit.
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
