cruises in Melb.
Guest JapCrazyImports
u know what shits me..
wen u get poofs in xr6's doin that
and they just dont give up
they accelrate and stop again and again
so u say ok fair enough
teach time. u dump and u teach them a leason.. a pretty hard one as well
and when they catch up they wanna do it all again.,..
some people never learn..
im sure you'll eat those words when the new xr6t hooks up next to you :)
Originally posted by pushead
I want to rewire the brakelight to a switch so if you get ****heads tailgating you, flick it on, they will definitely brake hard!
hehehe my old daewoo had a rear fog light switch.... i used to love it when ppl tailgated me (not for dragging puposes lol) cause id hit it and u just watch them drop back as i keep doing the same speed hahaha
Meggala - you're not that old! well maybe compared to a lot of people on here i guess you're not young but :D
Then again jet33 i think was referring to those 50+ year olds that drive an XR6, HSV, or whatever else mainly just for the status symbol and never push it.
Wait for 5-10 years and every 20 year old will have one - then watch out :)
Talking about XR6's i had my first run with a new XR6 turbo last night down princess highway in Dande!
I pulled up at the lights behind him near dande and kept flashing him tellin him i wanted to race, lights went green we both went, i pulled up next to him and he gunned it i gunned it and i preety much pulled away quite easily about 3-4 cars to 160 click, then i slowed down till he came again and then he gunned it again and caught me in 3rd gear at 60 click, i went back to 2nd caught him and as i started to pull away he slowed down, we did this about 4 times and eveytime i started to pull away he slowed down, the pu*ssy!
Couldnt see who the driver was as he had dark tint.
Conclusion new XR6 turbo aint the best thing since sliced bread, as every1 has been bragging about!
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
