PRICE DROP YO!!!!!!!!!
i have a couple of things for sale currently on my car but will be removed very soon or at time of sale.in no rush to sell but feel free to make offers.
IM IN NEWCASTLE, BUT WILL FREIGHT.
ALL PARTS OFF A 90 MODEL M SPEC GTS-T WHICH HAS JUST BEEN RESPRAYED IN QUICKSILVER COLOUR AND ALL IN VERY GOOD CONDITION!!
-bonnet very good condition no dents at all!-$170
-M spec front bar with active lower lip which lowers by about 2 inches at the push of a button or at speeds in excess 85ks roughly.-$220
email or pm me any questions or offers [email protected]
also have r32 gtr wing fibreglass copy currently black came off my s13 silvia should suit various other cars gtst etc? $80
PREFER PICK UP BUT WILL POST AT BUYERS EXPENSE
Edited by villain
https://www.sau.com.au/forums/topic/94210-r32-parts/
hey dude did you end up finding the r32 you wanted, i didnt go through with the sale of mine, ill miss it too much, so when does all your gear arrive gtr front bar bonnet grill etc good luck with the build
https://www.sau.com.au/forums/topic/94210-r32-parts/#findComment-1786601
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
