which exhaust...????
Guest JUNpowerYo!
sorr not emissions.... seems like its a sound thing
JASMA
Often owners may find 'JASMA' stamped on an aftermarket exhaust that was on their car when they bought it. JASMA is not a exhaust manufacturer, its some sort of organisation that certifies exhausts meet noise standards etc. It stands for Japanese Automobile Sports Muffler Association.
https://www.sau.com.au/forums/topic/9423-which-exhaust/#findComment-143060
I had Trust MX on my car, and it's quite loud compared to standard exhaust, but I like it after a while. It's pretty quiet when you cruise. The deep bass roar is when you accelerate around 2000rpm, by 2500rpm+ it's quiet again.
Nice.
https://www.sau.com.au/forums/topic/9423-which-exhaust/#findComment-143120
well, I got a kakimoto cat back, but the muffler was replaced with an american made N1 copy. I got front and dump pipes as well.
Got it tested yesterday for noise and with silencer I'm JUST bordering on legal (90-91db I'm getting, limit is 90).
Without silencer I got 92-93db.
With silencer was @ 3,200RPM
Without was around 3,000RPM
https://www.sau.com.au/forums/topic/9423-which-exhaust/#findComment-143705
