Gibson also rebuilt their engines every race meeting, oh and it was a race car running race fuel, we are talking street cars here that have limited fuel choices.
I got no idea what compression ratio is ideal, but the Group A cars were meant to be running on control Shell fuels. I seem to recall the fuel was not too exotic, actually i dont recall there being any mention of a fuel change when they changed from Grp As to V8s and these days they do run Shell Optimax. What the equivelant back in 90-93 was im not sure, but it wasnt too exotic
why do you want to run such a high C/R anyway? sacrificing reliabilty, my motor is 30/25 i have a C/R of 7:1 as it allows me to run higher boost and then bring my to4e66 turbo into range(round 25psi) allowing it to make good power. 480bhp with standard manifold, standard cams and stock camgears!
The bathurst sierra cosworths ran 5:1 C/R allowing it to run up to 45psi boost to bring the turbos into range!
7.1 holy god, that would be a pig of a car off boost.
I aint heard of that since the VL boys out West and thier "fully sick decomp plate" for 11ty billion psi
You dont need it to be that low at all for 25psi
Stick with the 9:1 it will work well, especially with a set of lumpy sticks.
Problem is there are no on the shelf pistons that get anywhere near that.. 8.6:1 I think is the closest you will get.
Unless CP's run some wierd pinheight, dome config.
it may not need to be that low but as it is my daily driving car on pump fuel with no additives it suits my purpose and i still have full boost by 3000rpm! and i have a mate of mine with a vl that had 9.5:1 c/r making 400bhp on 22psi and he melted 2 pistons as apposed to any mate of mine that has the exact same setup except he was running 7.8:1 c/r making 412bhp on 26psi and hasn't had a drama so imo i'd rather be on the safer side rather than pushing it to the brink! But that's just me :)
One solution is JE forged VG30DETT pistons at 87.5mm . The gudgeon pins are larger so rods need work .
If boost pressure is a measure of resistance to airflow then high boost is a lame excuse to get more air in . If you reduce the resistance to flow then same volume at lower pressure will make everything else easier . High boost pressure needs high fuel rail pressure/expensive pumps/expensive fuels/etc .
The RS500 YBD engine had a dog of a turbo making an unreliable pig of an engine for road or Grp A . You need to look at better examples than this .
Cheers A .
I was talking to Mick from Rocket Industries and he emailed me this:
The RB25 head has a a larger combustion chamber than the the RB26.
The dome on the AP332104 is .110" high. The dome on the AP332105 is .155 high. This will give more comp.
I spoke with our RB expert here and he reckons that the AP332105 might be a better option.
I believe the AP332104 are ARIAS pistons that give 8.5:1 CR and AP332105 are pistons that are used for RB26/30 convertion. I was advised to use the AP332105 pistons for RB25/30 convertion. Two questions though:
1. What kind of CR would this give
2. Would the higher piston sit proud of the block requiring thicker metal head gasket
Still... I wouldn't be going by what some one says..
Its much safer to simply measure it all up, you then know what + or - dome required. My Rb25 head cc'd up at 62.2cc's.
The Rb25 and 26 pistons also vary in their Pin height. So this is something also to look at if you want to optimize squish, which why wouldn't you for a little bit of research. :(
Edited by Cubes
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
