hey guys, just joined up coz i need some opinions.
moved to qld from south of perth 8 weeks ago. we de-tuned the engine so there isnt any detonation on regular unleaded because wasnt sure if premium was going to be available on the nullabor on the way here as i drove. currently making 285rwhp but we have taken a lot of timing out of it and boost needs to be turned up another 5 pound as well as taking off permanent closed loop etc etc.
unsure who to take it to because have heard reports of qld tuners trying to blow up motors on dyno to get rebuild from owners. preferably need someone who is good with power fc. i want her back up into the 400's and not blow up in the tuning process.
thanks for any help
https://www.sau.com.au/forums/topic/94398-brisbane-tuners/
just to add another opinion i did do a search on the qld section and it showed up bugger all. i looked for 'garage' 'mechanic' 'tuner' 'workshop' and got about 1 result for the place that used to be ADD. i just know of mercury from my mate.
https://www.sau.com.au/forums/topic/94398-brisbane-tuners/#findComment-1704279
Brisbane Turbo and Tuning centre come highly recommended by many people.
Mercury are good and one of the Forum sponsors.
Chapman and Chapman are quite good, they know their stuff.
Milanco are also very good and focus on customer service.
https://www.sau.com.au/forums/topic/94398-brisbane-tuners/#findComment-1704856
You're kidding right?...
https://www.sau.com.au/forums/topic/94398-brisbane-tuners/#findComment-1704942
i have head a Few storIeS abouT one of the above listed workshops and would think twice about going there, dont get me wrong, i have seen some good work come out of there to, why dont you go in and have a first hand look at some of the workshops for your self before you decide on anything.
Mike.
https://www.sau.com.au/forums/topic/94398-brisbane-tuners/#findComment-1705358
Obvisously there are going to always be a few people woth bad experiences. BTTC are the only ones who have done the right thing by a couple of my other mates.
Charlies are CRIMINALS! Every person I knopw that has gone there has been ripped off. Stuffed tunes, false reporting....you name it.
https://www.sau.com.au/forums/topic/94398-brisbane-tuners/#findComment-1706733
what about MazFix ?
If you got a microtech and rotors I hear they are good...
Few things. Depends on what computer is being run, what your car is as not everyone has an 4wd dyno. Because if someone has NO idea, they might be the worlds best tuner with say a motec, but usless on wolf3d. But I would say APC, PITS, or 101. There was a guy up toowoomba way as well, but I think he has moved as the workshop that used to recomend him now uses 101.
https://www.sau.com.au/forums/topic/94398-brisbane-tuners/#findComment-1707518
while this thread is still here and i cbf searching even though i should, does anyone know the website for 101?
They are in Judds Ct, Slacks creek. Pop in a have a chat I don't think their website is very informative. But I try and find it. <_<
https://www.sau.com.au/forums/topic/94398-brisbane-tuners/#findComment-1715861
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
