We are pleased to offer forum members this special offer new Autogauge Defi-style smoked face gauge bundle packs.
ABOUT THIS PRODUCT
This special Autogauge bundle package includes 3 of our new Defi-style smoked face gauges in 2 inch size, and 3 gauge DIN panel in which you can mount your gauges.
We have two bundle packages available
PACKAGE A
1 x 2 inch mechanical Boost gauge
1 x 2 inch electrical Oil temp gauge
1 x 2 inch electrical Water temp gauge
PACKAGE B
1 x 2 inch electrical Air fuel ratio gauge
PACKAGE C
1 x 2 inch electrical Oil pressure gauge
Each gauge includes sensors and required parts for fitting and blanks out completely when powered off.
These gauges and bundle packs represent outstanding value for money and are a fantastic value alternative to Defi gauges with no controller required.
We have a huge number of these in stock ready for immediate pickup & dispatch, so unlike other deals floating around the net, there is:
1. No deposit required
2. No minimum order
3. No waiting
4. Easy online payment options
5. No surprises
Deal with an established and trusted company! - Not a backyard trader
PICTURE OF THE 3 GAUGE BUNDLE PACKAGE FITTED
GRAB YOUR AUTOGAUGE BUNDLE NOW FOR ONLY $175!
(AUSTRALIA WIDE DELIVERY AVAILABLE FOR AN ADDITIONAL $20)
(NZ and TASMANIA CUSTOMERS PLEASE CONTACT US FOR A QUOTE ON FREIGHT)
So how can you place your order?
The answer is simple!
Visit www.justjap.com/parts_ngauges2.htm and purchase your 3 gauge & DIN panel bundle online quickly and easily via paypal or credit card, or drop by our Kirrawee factory and pickup your set over the counter.
Please contact [email protected] if you have any questions, or reply here.
Dont forget to check out our huge range of new and used performance parts and import vehicles via our website at www.justjap.com
  • Replies 58
Should do, best to take a quick measurement of your DIN space to confirm.
We have sold these bundles to many R33 owners and had no reports of problems fitting.
Cheers,
Steve
can you like change the gauges that are included in the package?
ie, if i already have boost and oil pres. on the pillar, and want oil temp, water temp, and 1 other in this pack, is that do-able?
Hi Dezz, give Darron a call on (02) 9545 0532 and he can work something out for you.
Regards,
Steve
We have heaps of stock remaining guys, get in quick to avoid missing out on this fantastic offer from Just Jap!
These are the 90 series gauges... any chance you might be getting the 270 series in stock??
90 series
270 series
thanks >_< i'd turn off the flashing if i knew how, btw.... it's making my epilepsy play up!
(Cross posted on NissanSilvia forums - thought others might like to know)
Edited by Beeble
We have the smoked studded face gauges with 270 degree dials in stock however they are dearer than the gauges we are offering as part of this promotion.
If you are after those ones in particular, we can put together a package deal for you
Regards,
Steve
Would these fit into the factory space in the center of the dash on a R34 Gtt. If not, do you know what will. I think the HPI R34 used aftermarket ones but I'm not sure what make or size they were.
Cheers
Cheers
Hi mate, we havent fitted the DIN panel to R34 GTT's as yet, so best to measure the size of the space you wish to use to fit the panel just to confirm if it will fit.
Steve
Hi Alex, the DIN panels are $29.95 and you can please your order online via our website
http://www.justjap.com/parts_ngauges.htm
They have tabs on the side for fitting
Cheers,
Steve
Thanks for all the orders guys, plenty left in stock ready for the Christmas rush!
Order online now!
http://www.justjap.com/parts_ngauges2.htm
Cheers,
Steve
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
