We are pleased to offer forum members this special offer new Autogauge Defi-style smoked face gauge bundle packs.
ABOUT THIS PRODUCT
This special Autogauge bundle package includes 3 of our new Defi-style smoked face gauges in 2 inch size, and 3 gauge DIN panel in which you can mount your gauges.
We have two bundle packages available
PACKAGE A
1 x 2 inch mechanical Boost gauge
1 x 2 inch electrical Oil temp gauge
1 x 2 inch electrical Water temp gauge
PACKAGE B
1 x 2 inch electrical Air fuel ratio gauge
PACKAGE C
1 x 2 inch electrical Oil pressure gauge
Each gauge includes sensors and required parts for fitting and blanks out completely when powered off.
These gauges and bundle packs represent outstanding value for money and are a fantastic value alternative to Defi gauges with no controller required.
We have a huge number of these in stock ready for immediate pickup & dispatch, so unlike other deals floating around the net, there is:
1. No deposit required
2. No minimum order
3. No waiting
4. Easy online payment options
5. No surprises
Deal with an established and trusted company! - Not a backyard trader
PICTURE OF THE 3 GAUGE BUNDLE PACKAGE FITTED
GRAB YOUR AUTOGAUGE BUNDLE NOW FOR ONLY $175!
(AUSTRALIA WIDE DELIVERY AVAILABLE FOR AN ADDITIONAL $20)
(NZ and TASMANIA CUSTOMERS PLEASE CONTACT US FOR A QUOTE ON FREIGHT)
So how can you place your order?
The answer is simple!
Visit www.justjap.com/parts_ngauges2.htm and purchase your 3 gauge & DIN panel bundle online quickly and easily via paypal or credit card, or drop by our Kirrawee factory and pickup your set over the counter.
Please contact [email protected] if you have any questions, or reply here.
Dont forget to check out our huge range of new and used performance parts and import vehicles via our website at www.justjap.com
  • Replies 58
Should do, best to take a quick measurement of your DIN space to confirm.
We have sold these bundles to many R33 owners and had no reports of problems fitting.
Cheers,
Steve
can you like change the gauges that are included in the package?
ie, if i already have boost and oil pres. on the pillar, and want oil temp, water temp, and 1 other in this pack, is that do-able?
Hi Dezz, give Darron a call on (02) 9545 0532 and he can work something out for you.
Regards,
Steve
We have heaps of stock remaining guys, get in quick to avoid missing out on this fantastic offer from Just Jap!
These are the 90 series gauges... any chance you might be getting the 270 series in stock??
90 series
270 series
thanks >_< i'd turn off the flashing if i knew how, btw.... it's making my epilepsy play up!
(Cross posted on NissanSilvia forums - thought others might like to know)
Edited by Beeble
We have the smoked studded face gauges with 270 degree dials in stock however they are dearer than the gauges we are offering as part of this promotion.
If you are after those ones in particular, we can put together a package deal for you
Regards,
Steve
Would these fit into the factory space in the center of the dash on a R34 Gtt. If not, do you know what will. I think the HPI R34 used aftermarket ones but I'm not sure what make or size they were.
Cheers
Cheers
Hi mate, we havent fitted the DIN panel to R34 GTT's as yet, so best to measure the size of the space you wish to use to fit the panel just to confirm if it will fit.
Steve
Hi Alex, the DIN panels are $29.95 and you can please your order online via our website
http://www.justjap.com/parts_ngauges.htm
They have tabs on the side for fitting
Cheers,
Steve
Thanks for all the orders guys, plenty left in stock ready for the Christmas rush!
Order online now!
http://www.justjap.com/parts_ngauges2.htm
Cheers,
Steve
    • Just wanted to unearth this and post my baby with the new front ❤️😝 Took her to my wedding rehearsal today. Next up is getting wide skirts (after wedding)
    • Yea, that is what I was getting at in my ramblings too. The nismo one actually is a 1.5 way and a 1 way. They don't do a *2* way because a true *2* way would have equal ramp angles. Or is that a true 1.5 way? Realistically I think a "1.5 way" does not actually exist. A diff can either lock in two directions or one. It also doesn't help that a LOT of people in Australia speak about 1.5 way diffs are referring to their 1 way diff.
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
    • Welcome Adam. Car looks great!
    • "With a 1.5-WAY, the LSD is effective only during acceleration."
