I can see that at some stage in the future this thing is going to get ripped off on a driveway or something.
What Nissan Dealers in Melbourne have people used to source R32 GT-R parts?
Can I assume that as they were locally delivered at one stage that they are easier to get than other models?
Has anyone bought a new lower front lip from Nissan at any stage and how much was it?
Regards
Andrew
https://www.sau.com.au/forums/topic/94803-r32-gt-r-parts/
Well i'm guessing the one you bought from carmate is fibreglass, the original nissan ones are a plastic. Fibreglass will be destroyed the first time you hit it, the original nissan ones can take a beating...
Yeah, I'm only interested in genuine parts. ABS plastic is definitely the go with this sort of stuff.
I did see somewhere that Brighton Nissan is good to deal with?
Anyone else?
Andrew
Edited by BBGTR
https://www.sau.com.au/forums/topic/94803-r32-gt-r-parts/#findComment-1711996
Andrew - Talk to Trevor at Brighton Nissan.
Tell him Marcus sent you.
The front lip is $400 retail I think - he should be able to do a bit better.
Cheers
PS and for that matter they actually carry alot of import stuff... I get all my bits for the 32R from him (if buying new that is)
https://www.sau.com.au/forums/topic/94803-r32-gt-r-parts/#findComment-1713593
Cheers
Cool, thanks.
I'll go down there and pick one up I think - I'll tell him (Trevor) you recommended them.
Cheers
Andrew :)
Edited by BBGTR
https://www.sau.com.au/forums/topic/94803-r32-gt-r-parts/#findComment-1721464
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around with a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
