Originally posted by Works Auto
Yeh i did a pb tonight of 13.3 @ 107.8 mph.
I could have gotten better but kept missing gears , oh well..
I think its not bad for stock turbo , stock management.
Missing gears?
Have you got a truck gearbox or something, how many gears can you miss?:)
Guest Works Auto
reason i was missing third gear was because i thought i might try some redline shockproof.
I found its excellent for protecting the box but doesnt allow the syncro's to spin up quick enough. So i was having trouble getting third , just woudnt go in.
So i came home put ELF gearbox fluid back in and its back to normal.
So far the box is holding up but its getting whiny .... i think its on a life expiry ... going going BANGGGGGGGGGG
14.6 thats damn good for a almost stock car man !
I was down at the plex last meet with Imacul8 and noticed that the VT range of HSV's ( including Utes) where only running 14.7's and up.
Pretty lame for a hard arse car......
Why Jap cars are better than late model domestics part 1.
thanks guys at least im improving i think the car is able to do better its me that needs to perfect the techniques but im happy especially as its a auto and all. I might stick with it as stock this season then do some work - like pod and cat back exhaust, boost controller and see what the improvement is like
    • R34DE as in R34 with an RB25DE? So did you get this? Or you planning to?  I'm not really sure what you're saying.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
