Dear people,
I have conducted a search and found no info, so i need your oppinion.
I am currently building a meduim to high hp rb 30 /26.
I have assembled the bottom end and all good gear has been used .
BUT dam it i did not get the crank oil pump collar widend.
No one over here in WA does it any way.
I have just been informed that this was a crucial mistake and my N1 on the standard crank will not last 5 minutes , i tend to disagree.
Is it mainly in tired r32 rb26 engines that they let go ?
If this is the case what if i replace every , say x amount of km's.
Will this help or is it simply an hp issue.
Sometimes i wonder if some things i get told from tune shops are simply a "turnover factor " . Please enlighten me on this if you would not mind , are there any alternative measures i can take . some one mention a collar that can be bought or made .
Thanx
https://www.sau.com.au/forums/topic/94855-oil-pump-crank-collar-r32-rb3026/
i brought a JUN crank collar about 200 bucks from greenline but i think these are grub screwed in so may be hard to fit if engine is together.That was for an R26 crank not sure about the R30 cranks
Edited by blk180
Thanks for that, can't see why cant locate as engine is on the bench , How has it been so far?
Are you using your Air con or going the full race path because i know of a company that can to good exturnal pumps.
Steve,
no air con , no factory fruit at all , just about drag specs.
External pumps , tell me more please.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
