Pwoh nice! Is that "Aero Special" a 1:24th scale? and was it from that Rainbow 10 place?
1/24th scale ordered them both from www.hlj.com i could spend thousands there
just for instance
http://www.hlj.com/product/yod50522
Edited by rsx84
https://www.sau.com.au/forums/topic/94871-new-toys/#findComment-1718624
Who makes the "aero special" DR30 kit? is it Fujimi or Aoshima?
I've got the Jenesis DR30 kit in mid build, and a KPGC10 with a transplanted L28 with webers in place of the S20 (really an L24 from a fujimi 240z), a C110 GT-X "bosozoku" style with massive camber, stretchwall tyres etc, and FIVE HR31 Skyline kits (one of them is the 4 door hardtop). Hopefully I can finish them all
Aoshima made these stretchwall tyres + deep dish old school wheel sets for a series of bosozoku style kits - not the "works" series HLJ have, something completely different that only aoshima hobbyworld japan stocked - they're insane! I've got SSR MK1s, Longchamp XR4s, and Yayoi Sakura...
same model as ^ I was trying different wheels
https://www.sau.com.au/forums/topic/94871-new-toys/#findComment-1722943
Well since we're adding pictures... here's my 240ZG WIP. It stopped several months ago cos I was up to painting the body and ran out of maroon paint. The toy shop stopped selling this brand so I put it on hold. Haven't really got back into it as haven't got the time + $10 per can doesn't excite me even if I could find somewhere that sells it. This model is the best model EVER, so detailed and mostly accurate. So I'm trying my best to paint it accurately too. If anyone is interested there's the same kit on ebay atm - no relation to seller.
^ Dashboard
^ Very difficult to do detailing here
^ My best attempt at "woodgrain" for the steering wheel. Looks nice but not as dark or as red as the real thing.
^ Completed engine + tranny !
^ All of the bits I've painted/assembled so far
^ Sad looking HS30-H in paint prep
Edited by Alfadog
https://www.sau.com.au/forums/topic/94871-new-toys/#findComment-1724343
I've got about 9 kits from hlj downstairs that I need to finish before I order any more.
Need to redo my stock DR30 because the black rub strips look crap, theres another 1 or 2 stock DR's, a Jenesis DR, a HR31 coupe, a hakosuka, a two door and a 4 door 240K race cars, a KE70 that is going to get some deeeeeeeeeep dish Watanabes that are supposed to be for Testarossas or something, S5 RX7, early Soarer (done the shell, sparkly apple green). I think thats it. Might redo my V8 S13 sometime too
https://www.sau.com.au/forums/topic/94871-new-toys/#findComment-1724667
the aerospecial is Fujimi
love me models (of all types) had a old chev step-side truck that i put a V6 fuel injected engine in, ford XP ute, plus a few OLD dragsters too. now i've got a few new ones in the cupboard, r32 gtr r33 gtr r34 gtr, i got a evo3 too..
have found a few toyworlds stocking older models now, one in southprot here i came across a r31 passage 4door, rx7 and rx3
Edited by rsx84
https://www.sau.com.au/forums/topic/94871-new-toys/#findComment-1724802
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
