turbo timer
after driven hard between 2-5 mins or even more
my turbo timer is one of the newer Greddy Timers
so like many other timers it calculates a countdown time according to the rev's cycles or sum shit like that
the harder the revs cycle the longer the countdown time
or sum shit
adrian
https://www.sau.com.au/forums/topic/9491-turbo-timer/#findComment-143489
Andrew,
My personal opinion are that they are a waste of time, unless you have driven around a track then I don't think that there is any need, and if you drive it hard then just let the engine idle for a few minutes before switching it off. I know lots of high-horsepower cars that don't use them, just another unwanted bit of rice.
See'ya:burnout:
https://www.sau.com.au/forums/topic/9491-turbo-timer/#findComment-143491
Well they ARE convenient if you need to get out of the car in a hurry but you dont want to turn the car off. So in that sense theyre good, i generally idle my car down out in the car park across the road because the neighbours go spastic at me for doing it in the car port. So my HKS timer rarely gets used. But it came with the car, so i no complain.
I wouldnt call them unwanted rice, but more a convenience like, power windows, adjustable seats, power mirrors, a cd player etc.. Shall i go on? :)
Red17
https://www.sau.com.au/forums/topic/9491-turbo-timer/#findComment-143683
I made my own turbo timer from a Jaycar kit, cost me $35 all up, it's completely concealed. NO ugly switches/boxes and no rice... just the way I like it....
They're convenient ? yes. Rice? "each to thier own"
I don't like the look of them. Mine is hidden under the steering column WAY outta reach.
https://www.sau.com.au/forums/topic/9491-turbo-timer/#findComment-143847
hahaha
i read about them N/A Electronic Blow Off Valves
hahahahahaa
and they are adjustable just like the real thing
only thing is you adjust the speakers volume not the spring tension
hahahahahahahaa
yessssssssssss go get one right now all you n/a owners!
https://www.sau.com.au/forums/topic/9491-turbo-timer/#findComment-144135
joe why buy one?
i have two suggestions!
1) tape record yourself making the pShhht noise or wateva custom BOV noise you want then play it through ur stereo with the speakers on full volume and your windows down!
2) Drive with your windows down and make the psssht noise with ur mouth as you drive past people!
there you go home made blow off valves for N/A
adrian :)
https://www.sau.com.au/forums/topic/9491-turbo-timer/#findComment-144195
hehehee
oh well revert to option 1
but you may need a remote to conitnously play the blow off noise through your stereo!
otherwise you'll have to keep reaching over to pause and play then rewind pause and play !
:D
option 3 GET A TURBO CAR hehehehe
adrian
https://www.sau.com.au/forums/topic/9491-turbo-timer/#findComment-144352
    • Hi, i’m making a rb25det coil loom for Vag short coil. Can anybody tell me which Ecu signal wire belong to coil number 1 and 2,3,4,5,6? The connecting switch in above pic is 8 wire i think white is for +12v and black for earth.
    • Was there ever a model of the Stagea m35 that didnt have a badge on the grill? I thought I saw that somewhere, some aero edition or something? I cant find it again? davemoto
    • Its a 2002 vr-x four VQ25DET, silver. Coil overs, lowered, polished alloys and sport exhaust. Bit of a project, was sitting in a shed for a while but runs and drives great.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
