  • Replies 169
Posted Images
Awesome guys!!!
Good turnout already on the list too.
Once you get to Newcastle you may find it a tad hard to find parks where Jeff has shown on the map on the initial post. A good place is Bar Beach Carpark, its bloody huge!! Otherwise, sounds like you guys have got things well under control & under way.
Us Newcastle boys/gals shall be travelling up to Nelson Bay on the morning of the 18th, then travelling back to Newcastle straight after lunch/photoshoot at a marina (Courtesy of DiRTGARAGE). So what we'll have to do is get each others mobile number and just see where the other group is at and if its possible to meet up for an afternoon meeting before you guys head back to Sydney.
My number is: 0417268091. I can ring Jeff and see whats doin on the day. We will all have UHF radios so once we get close enough to you blokes we can communicate that way.
On a final note: If you guys get bored, im sure you wont, but if you do... Head over the Kooragang Island. Its the grim industrial sector of Newcastles harbour and quite suprisingly, has some MEGA photo oppurtunites. So be sure to bring the camera too!!
Talk to you soon,
Dave.
Awesome guys!!!
Talk to you soon,
Dave.
thanks dave, we look forward of meeting with you :P
So when are people guna be in nealson's bay?? Like what time in the morning?
Talk to d-d from the newcastle crew, wer not going with them.
wer mettin them back to newcastle in the afternoon.
if u wanna go with them the will meet at the foreshore at 10am
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
    • Assuming your brake pads are not worn right down, I'd add a little brake fluid. Is there any sign of a brake fluid leak?
    • Hello all,  I need of some help. On my drive home my handbrake light lit up and started flashing. When I got home I checked my handbrake sensor under the centre console and nothing seemed out of the ordinary. I have scanned my car via the consult port, no codes shown. Checked my brake fluid as well which is half full. Tried unplugging the brake master but it didn't change anything. Thoughts on what it could be? The master float doesn't seem to be stuck. My car is an 1998 ER34 sedan GT. No hicas but has ABS Photos below 👇🏾
