  • Replies 149
macers is off showground road, up the castle hill end (think it could be old northen raod end) .. ether way its near the shops end, hard to miss, just look for the big yellow thing :D
oh and yep ill be there at macers too at 8am with moanie
All good.
Have just checked the forecast and it looks like we can expect some good weather tomorrow. Hopefully, we can also expect a good turnout, with around 65 RSVPs.
Don't forget to you'll need to have at least ONE current member of the SAU NSW Club in the car to come along (non-members can join on the day). This goes even if you're not planning to do the observation cruise because the entire event, including the barbie, is covered by CAMS permit
Any club member who can't find a passenger but still wants to come to lunch should meet at Krispy Kreme. We'll still need you to sign the entry form and will provide details of the final destination once the last cars doing the observation cruise have left.
Don't forget to fill your tank before getting to the starting point, the cruise to lunch is over 150klm :D
Don't forget to bring a picnic blanket/ chairs etc to plant yourself on at the end
If anyone gets lost in the morning, or has any questions, you can call me on 0412 530 276.
Otherwise see everyone tomorrow!
Kel
Kel can you take me off the list...
I cant make it.....work committments means less time to study.
Silver PM me your number and depending on what time you leave I MAY be able to cruise with ya to the destination
Can you send me a text if you look like making it to lunch?
We'll need to orgainise an entry form for you, just in case you fall on the barbie/ trip in the car park etc etc etc
Thanks
Kel
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
