It doesn't surprise me that the WSID website has old information on there. They were probably too busy rewoking the private track hire rules that they have recently published. :D
  • Replies 168
I hope you're right NXTIME.
I just looked at the list now and it looks like it has been updated...now 24 cars in total :)
I still haven't got around to entering yet, but will do so next week. I just hope the event gets the numbers otherwise it's going to fall on it's arse and be another slap in the face for SC in this country.
Despite the very low competitor list that is currently on the WSID website, I know that there are quite a few more cars that will be entering this week. Alot of them are also coming from interstate.
That's good news then :)
TWO new PRO RWD cars making their debut!
Adrian
Even better news :)
Here's hoping that the event is a big success.
I personally enjoy watching all types of drag racing (and motorsport in general), but SC is the only hope I'll probably ever have of actually competing which is half the beauty of the concept and which is why I'm going to enter. I know this is probably true for the majority of people on here, so if you're thinking about having a go, just get in there and enter :D
handed out approx 300 flyers at Autosalon today premoting the event....will hand out the remaining 200 tomm. hopefully we have some competitors/spectators amongst them
Because your racing against more fancied opposition ....why do footballers want to play 1st grade????
That's it. It's all DYO anyway, as long as you can qualify in the top 8 or top 16 cars.
What times did you run, PORTS?
Do you HAVE to run slicks in Sport Mod, or are you allowed to if you choose to?
Best run a ball tearing 15.952, a PB for the sled, worst run was a 16.154, six runs in all.. :D
Last 18 runs have all been between the above times. Think i'll DYO a 15.9 for the dragwarz. I'm not sure about slicks, as this will be my 1st event of this type, so running semis.
do you realise 14.5 is the qualifying cutoff for sport rwd and slicks are not permitted....you'll have to race in et2 bracket. It would be worth your while to consult the rule book if planning to run next Saturday.
EDIT: they have either botched your entry or you have a very sluggish PRO RWD car....as they have you in with PAC and Dalton's...good luck
Edited by DiRTgarage
SHIT !!! Spoke to John on the Al Capone twice and in person last nite and I told him my times and was told that was not a prob, and they would stick me in some category. (cardigan wearers I guess?). Have paid up so wtf?
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
